My 997 Todo List / Notes
Rear Brakes - Hawk Ceramic
https://rennlist.com/forums/997-foru...a-997-2-a.html
Rear Tires (done)
Paint chips
option1
Get Waze in my car
- CD slot mount - Koomus
- ipad mini install ? https://rennlist.com/forums/rennlist...l#post12684032
Treat the Leather
Better Floor Mats
Fix Tire emblems [look bad - yuck]
Backup Camera https://rennlist.com/forums/997-foru...options-2.html
- how to run the wire -
Collision Detection
Fix Driver's Door Handle
https://rennlist.com/forums/997-foru...l-removal.html
ipad mounting (replacing PCM) -
Soundman Ipad Kit to your dash
ipad - backup camera - http://4ucam.com/iphone-android-ipad...up-Camera.html
Need Tires:
Michelin Pilot Sport PS2
Bridgestone S04s - are less than 1/2 the cost of the PS2s
Continental Extreme Contact DWS
CONTINENTAL EXTREMECONTACT DWS
Ultra High Performance All-Season
Front: 235/40ZR18 95Y XL
Sidewall Style: Blackwall
Qty:Per Tire: $146.68 USD
Availability: In Stock at TireRack.com
Rear: 295/35ZR18 99Y
$243.00 USD TireRack.com
235/40R18 Front
265/35R18 Rear - In stock Canadian Tire $289.99 5-8 days to order
O.k. Tire Store (burlington)
545 Plains Road East
Burlington, ON L7T 2E4
(905)333-9990
fax: (905)333-4263
$312 + taxes at OK tire (not in stock). 5-8 days to order
OK Tire said there were 4 of them at the Conti warehouse in Oshawa.
I ordered 2 @ CT for pickup. $289.99 each + tax + 9.50 enviro fee = $666.12 CDN
Parts
Continental ExtremeContact DWS 295/35/18 ZR 99Y (rears)
Continental ExtremeContact DWS 235/40/18 ZR 99Y (front)
Regarding the leather conditioner, I highly recommend Zaino Z-10
Lexol products on my leather and they work very well. They make a cleaner and a conditioner that are expensive, but they do a great job if you follow the instructions. I use these products a few times per year.
brake fluid every 2 yr
Oil: every 10,000 kms. 5k miles. WalMart sells 5 quart bottles of Mobil1 for $23
coolant,
trans fluid now
- Serpentine belt (usually done before 60K miles)
https://rennlist.com/forums/997-foru...tine-belt.html
- Spark Plugs and coil packs (if it has been done earlier then ignore) at 60K miles. (or 4 years)(to prevent seizing)
- Water pumps are often failing by 60K so this is an optional item - typically start to leak or make noise before they fail
- transmission oil
- brake flush and check brakes
a major service with spark plugs at 40k
New plugs at the dealer will run you $400 installed.
- no anti-seize grease
- $65 for a set of plugs for a 997.1
- http://www.pelicanparts.com/cgi-bin/...itemquant=%206
http://www.pelicanparts.com/techarti...p_Your_Car.htm
http://www.pelicanparts.com/techarti...Oil_Change.htm
Oil filter kit, 7"10 quarts of motor oil Add about 8 quarts to the engine
8mm hex socket tool to remove the drain plug from the bottom of the engine sump.
live in a cold climate, you should use a 10W-40 or similar oil.
Motor oils and the additives blended into them have improved so much over the years that frequent oil changes and expensive synthetics are no longer necessary.
However, if synthetic oil was the only type of oil that your engine has seen, I usually recommend sticking with it.
Brakes
http://www.pelicanparts.com/techarti...Brake_Pads.htm
Spark Plugs
https://rennlist.com/forums/997-foru...-plug-diy.html (997.2).
Plugs
Coolant
Water pump
Gear lube
Thermostat
lift and inspect all seals.
Punch the VIN into the IMS Bearing lawsuit website just to double-check that your car doesn't have the smaller bearing.
Porsche calls their coolant "lifetime coolant" that should be good for 80,000-100,000 miles.
Sunroof maintenance and lubrication.
https://rennlist.com/forums/997-foru...tion-tips.html
Apps for maintenance: auto care
New Key: https://rennlist.com/forums/997-foru...h-a-twist.html
Stickers
https://rennlist.com/forums/997-foru...l#post12838367
Bought this smartphone CD mount
Seats are out of an 2006 so should fit: 2005-2008 911s/Caymans/Boxsters.
MAHLE Oil filter
http://www.pelicanparts.com/catalog/..._pg3.htm#item9
I've never had a squeal, but then I am careful to put back the proper OEM anti-squeal shims that sit between the pads and the pistons. I gather a lot of people skip these but they are there to help stop squeal (regardless of whose brake pad you are using, OEM included)
So far I've been able to use a narrow putty knife to pry the existing ones off whole (before removing the pad) and reuse them successfully. New ones are a bit costly.
Paint chips
option1
Otherwise I can't think of any mods I want to do, it's perfect just like it is. Will save my time and money for upkeep. Bought a new set of OEM mats on sale from Suncoast. Just re-dyed the shifter and e-brake leather. Next project is Dr. Colorchip for a few nicks here and there.
Treat the Leather
Better Floor Mats
+997
It can pay for itself by avoiding one visit and it can do a plethora of other things.
I got mine at PelicanParts for $287 + free shipping and had it in two days.
Buy a Durametric
http://www.pelicanparts.com/catalog/...pg5.htm#item17
Buy a Durametric
Need Tires:
235/40R18 Front
(905)333-9990
fax: (905)333-4263
Parts
coolant,
trans fluid now
- transmission oil
Brakes
Spark Plugs
Plugs
Coolant
Water pump
Gear lube
Thermostat
Stickers
Koomus Pro CD-M Universal CD Slot Magnetic Cradle-less Smartphone Car Mount Holder for all iPhone and Android Devices: Amazon.ca: Cell Phones & Accessories
Koomus Pro CD-M Universal CD Slot Magnetic Cradle-less Smartphone Car Mount HolderSeats are out of an 2006 so should fit: 2005-2008 911s/Caymans/Boxsters.
MAHLE Oil filter
