Installing a wing from a Turbo on my C2S
Old 04-24-2017, 02:45 AM
  #121
Ditchhanger
Ditchhanger's Avatar
So these 3/8" plugs are a little bit too large for those holes...the 5/16" may fit better, but I don't think they'll be as snug. I just shaved about 3/8" from the bottom where the insert is and it fit in there pretty snug...it's not going to come out without some effort.
Hoth22 (12-24-2019)
Old 04-24-2017, 02:50 AM
  #122
Ditchhanger
Here's where you have to modify your EVOMS. I know...drilling a hole I to a perfectly designed $600 intake may not be the thing you want to do, but this wasn't made for this exact application. I left the bolt in the plug and set the intake box (no filter or tube coming from the throttle body attached) as far left as possible (without it angling up on the left side) and kind of made some marks on the bottom of the box. Based on where the plug sits in relation to the box, I used a 1/2" drill bit and drilled in from the bottom. I had to elongate the hole a little towards the right side (if you were looking down into the filter space) but the rubber part of the plug fits nicely.
Old 04-24-2017, 02:57 AM
  #123
Ditchhanger
Now that it's pretty secure in there, you can do the same for another one of those holes, but I just left it with one. Once the intake tube is attached, it's quite solid.
The other issue is that even though it's now situated as far as it can go to the left, the right side piston was still coming into contact with the filter box. I took a MAP torch I had laying around and proceeded to take off the rubber strip and heat up the ABS where the piston housing was coming into contact with the box. You could use a heat gun if you want, but anything else won't provide enough heat. I then just gently massaged the plastic just enough to make the piston clear. It does take time and if you use a torch, be prepared to wear some thick gloves to massage it with your hands...it'll be hot. Also, don't put direct heat so close to the plastic...take your time. You don't want to use any tools because since the plastic is somewhat pliable, it'll leave marks
Old 04-24-2017, 03:00 AM
  #124
Ditchhanger
After that, you have to kinda fit the filter in the box and then of course the intake pipe into the throttle body. It takes a little bit of work, but it's not too hard. Also, don't worry...the filter can be installed and removed from that space (the plastic is pretty flexible there and strong). Then replace the rubber strip, and you're good to go!
Old 04-24-2017, 03:03 AM
  #125
Ditchhanger
And the finished product!
Old 04-24-2017, 04:25 AM
  #126
Ditchhanger
So whoever is doing this mod next and wants to use the spanner wrench, PM me. I'll send it off to you and then you can send it off to the next person who needs it.
Old 04-24-2017, 10:52 AM
  #127
Petza914
Petza914's Avatar
Received 6,452 Likes on 4,113 Posts
Nice work and valuable update. Looks like you inserted the plugs through the airbox and then into the chassis mounting holes. I did it by making a hole closer to the size of the bolt and used a neoprene washer with a stainless washer to make an airtight seal. Either way will work and yours needs fewer parts, but a larger hole.
Also, I'd recommend installing a hydrophobic K&N pre-filter over the oiled filter. With the turbo decklid, the filter is pretty open to getting wet when it rains. I have the specific # of the cover I ordered at h OK me and can post that on Friday of this week when I'm back. Comes in various colors.
Old 04-24-2017, 04:01 PM
  #128
Ditchhanger
I actually used that metal washer between the airbox and the plug from the inside. The plug was inserted into the holes, then the airbox on top of it and the bolt with the washer going into the plug from the box side.
Old 04-28-2017, 12:10 PM
  #129
Petza914
Petza914's Avatar
Back home again...the K&N hydrophobic filter cover that's a good fit for the filter on an Evoms airbox is RF1048DR. The last R denotes the color and they come in Black, Red, Yellow, & Blue.
Amazon Amazon
Old 04-29-2017, 05:10 AM
  #130
Ditchhanger
Thanks! They only had the red on Amazon, so I went to the K&N website and got the black one for the same price with free shipping!
Old 11-03-2018, 01:16 PM
  #131
EG997C2
EG997C2's Avatar
I'm in the middle of gathering the needed parts for the conversion on my Guard Red 997.2 C2S and have to say that this thread made things soooo much easier. Thanks to everyone that contributed.
Does anyone know if there's a way to wire the spoiler into the C2S harness to avoid purchasing the Turbo lid harness?
Old 11-13-2018, 10:38 PM
  #132
Ditchhanger
Did you purchase the parts piece by piece or did you source out a complete wing and decklid?
Old 11-13-2018, 10:58 PM
  #133
Petza914
Petza914's Avatar
Even if there is, I'm not sure it's worthwhile to do it when the proper turbo wiring harness is simply plug and play with the existing connector. It's the hydraulic pump that's different on the turbo so there are connection points in the non-turbo connector that are blank that have contacts in them in the Turbo harness. Isn't the turbo harness, like $100? Go that route so you don't have pin issues and you have a waterproof connection that doesn't cause you problems down the road. The setup I did in my wife's car has been completely trouble free for 5 years since we did it in the Spring of 2013.
Have you found the hydraulic rams and pump yet? I still need to do the Eram conversion to her car with the parts sitting in my office closet, which would make her hydraulic setup available for sale. Let me know if you're interested and I may move some project timelines around to free it up for you.
Quick Reply: Installing a wing from a Turbo on my C2S
