What did you do to your 997 today?
#6121
Those night photos of the C4S really make be wish the reflector on the rear deck illuminated too.
#6122
Oddly enough, never did take any photos after install. just ran outside and snapped a couple for ya. dirty from daily duty, and not the best quality, but you get the idea
#6126
#6132
Replaced Rear Wing Hydralics with Erams
I replaced the Active Aero wing hydralics on the RUF 997 with Rennkit's Erams in order to achieve 1" additional wing lift vs the stock hydraulics and to not have to deal with future leaking of the cylinders which they all seem to do eventually.
Everything about the RUF rear decklid is non-standard so fitment, spacing, wiring, threads into the wing etc is more complex than it would be on a regular 997TT decklid, but turned out great.
#6133
Replaced front trunk gas sprigs (struts)
Last weekend I removed my front bumper on my 997 Turbo and did a deep cleaning on my radiators and had to fight with the front hood to keep it from falling so I decided to change the gas springs out. I decided to try a set of gas springs from an unlikely source. I order from McMaster-Carr.com every day or so and my company buys and uses gas springs by the hundreds. I removed both springs and tested them against a bathroom scale and found they were 60Lb on one side and 30 LBs on the other. I figured the strong side probably lost a bit of pre-load so I ordered a pair of 70 Lb gas springs part # 9416K12 @ $13.17 each and 4 snap-on ball socket ends #9416K86 @$1.48 each to make the overall length of the assembly roughly what i measured on the OE springs. I popped them on and they work like new. the shafts on the McMaster springs are a bit smaller in diameter than OE but since they are in compression and are offered all the way up to 80Lbs I don't see a problem. here are the links to the pages . https://www.mcmaster.com/#catalog/123/1263/=19xyeqo and https://www.mcmaster.com/#catalog/123/1262/=19xy673
Not sure what the dealerships get but a gas spring is a gas spring and the new parts cost $38.50 including shipping and they got to me the day after i ordered them.. I love this company
#6134
OEM stabilius units are $21 each at fcp euro, so I'd probably just go that route.
https://www.fcpeuro.com/products/por...an-92643021366
#6135
