What did you do to your 997 today?
#2808
Maybe they don't want to attach radiator protection with plastic zip ties on their $100K sports car? Or they don't have the fins to tie them to...both true in my case. No cheesy mods allowed!
#2809
If you can't see the zip ties from 2 ft away does it make any difference? Is it still "cheesy"? Is it worth an extra $265 ($3000 Can)? Thanks but I'll stick with my cheesy mods and pocket the cash
You sound like the guys that MUST have a $3000 PSE system because a cheesy $300 gundo hack that sounds exactly the same doesn't come with the Porsche tax
And with reference to your beloved $100k sports car, I don't know about your 2006 but I wish mine was worth $100k. Pls!!!
#2811
Look closely and you can see the black cable ties that are wrapped around the black fins. It blends in so well you can barely see it even when looking for it ![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
there a couple of threads on this DIY
https://rennlist.com/forums/997-foru...s-for-5-a.html
https://rennlist.com/forums/997-foru...protector.html
I got the mesh from Home Depot or Rona's (Canada). Its just metal gutter guards - $10
I think this is an inexpensive solution and it allows easy excess just in case.
#2812
Louis be careful as it may rapidly depreciate the value of your car!! It will be *gasp* cheesy ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Or you can spend $275 for something that you can do yourself for $10 then your 2006 will be worth $100k!!
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#2814
Celebrated my one year anniversary of stewardship of my 2010 C4S. I've put just about exactly 25K miles on during that time. Spent yesterday doing the 60K service/inspection minus the PDK clutch oil change, four wheel drive controller oil change, and coolant flush. Some things don't DIY as well as others.
Loving every minute with this car, even though it has lost major value due to the Home Depot radiator screens!
#2815
I replaced my 997.2 engine air filters. Bought Mann filters. Car has 31k miles. Filters looked pretty dirty. Easy job. Eight screws on the cover then one clip. One screw on each filter. Total time about 30 minutes.
#2816
Sir Thomas Lord of All Mets Fans
This past weekend, drive it on the track at Texas Motor Speedway! Three laps, as part of Laps for Charity.
T
T
#2818
Edit: This is it before I cut off the excess piece.
#2819
If you go that route, then I also suggest that you find a long flat surface (granite counter top, glass dining room table, etc.), tape the hose down with wide tape (masking, duct, etc.) in a straight as possible line and start slicing it open. BTW, if you're going to use one of the flat surfaces that I mentioned... get your wife's permission/approval because trust me I've been there!
The splitting may be a bit time consuming but I think that it might look better than some of the "black tape" suggestions sometimes mentioned. Anyway, just another alternative for the thought process.
