PCM 3.0 Integrated Wireless CarPlay/ Android Auto
#226
In theory you want to do that D/A conversion as late as possible, right before audio amplification, as digital is much less susceptible to noise and distortion as it travels along the signal path. So that would make the MOST units seem like the better choice since it's not passing analog signals between boxes. However, there's some inherent assumptions such as the head unit's D/A's are of comparable quality to that used in the "Aux in" units. Plus there is almost certainly some reformatting of the digital signal within the "MOST" units to convert it to a comparable format used in MOST. Again, we are assuming this was done competently and didn't cut corners.
So yes, I would agree that the MOST boxes do seem to be a technically superior approach but the devil is in the details on this stuff. Just claiming the MOST boxes are digital and therefore better isn't the full picture. That being said, I'm leaning towards the MOST box myself as the things I mention above aren't rocket science.
I appreciate Roman's comments here and would much rather deal with US support than some guy in China running emails through google translate. But the name "Mr 12 Volt" is kind of silly sounding and IMO trivializes what looks like a great product.
#227
I am curious if anyone has gone the Becker route? My head unit died, and I have not seen a decent deal pop-up on a used one. I am sending it back to Becker for refurbishment.
Becker offers a Carplay upgrade when they do the refurbishment for $700. I am curious how it compares to the units. mentioned here.
#228
I am leaning towards the Mr. 12V/Rennkit setup for my soon-to-be delivered 2009 997.2 Cab. The challenge I am working through is whether the video board will "fit" inside the PCM chassis if there is a factory SiriusXM unit installed. If it is a matter of simply adding support post extenders, that is not really an issue. If however, adding post extension to properly clear the XM unit but then creating ribbon clearance issues that becomes problematic.
I've asked Dave, and he noted that some customers have in fact done exactly what I am proposing to do. I just don't have an answer to the extension/clearance question. Can anyone offer experienced input here? Really appreciate it.
Toby
Toby
#229
Basic Sponsor
Toby
Toby
Modernize your P-Car w/ Mr12Volt. Apple Carplay and Android Auto with superior audio quality, features, and support. Reach out for specials! Torque.Acs@gmail.com or Roman (267) 317-8229
Our website is now LIVE! please visit us at www.ACSByRoman.com
COUPON CODE "toys" FOR FREE INSTALL KIT!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
Toby Pennycuff (09-07-2023)
#230
Toby
Toby
The following 2 users liked this post by doclouie:
Roman ACS (09-07-2023),
#231
Toby
#232
RennKit-Dave (09-07-2023)
#233
I have a new Joye Auto PCM 3.0 Wireless Apple CarPlay / Android Audio unit for sale in the Marketplace
https://rennlist.com/forums/market/1357781
#234
It is really tight with the ribbon cables, particularly if you have a PCM 3.0 with multidisc changer. If you just have a single disc player (like I do), there's a huge amount of empty space in the top half. There's a thin metal piece snapped into the top half that separates it from the bottom half. I just left it out and it opens up plenty of room available for the ribbon cables. No problems whatsoever so far from leaving it out.
The following 2 users liked this post by PV997:
RennKit-Dave (09-08-2023),
Toby Pennycuff (09-08-2023)
#235
or just buy your mr12volt directly from roman and he includes the standoffs you need. that's what i did.
The following 2 users liked this post by signde:
myltz400 (12-20-2023),
#236
I bought this assortment and ended up using 35 mm (20 mm and 15 mm stacked). Make sure you get 2.5 mm for the threaded portion.
https://www.amazon.com/dp/B07FMV5RMG...roduct_details
Toby
#238
@Roman ACS Good morning Roman,
I did receive my Mr. 12Volt unit for my 997.2 PDK. I'm planning to install it in the coming days and wanted to confirm a few things prior to attempting installation.
Thanks in advance for any answers you can provide.
Toby
- I've seen plenty of posts in various threads on this 997 Forum regarding backup camera issues. I have the Natika backup camera from Amazon () This camera's resolution is 950x576 but I cannot find any frame rate information. Is this camera a supported option? Assuming so, what configuration options are suggested in the Mr. 12Voly unit to properly accommodate this camera?
- For the DIP switches on the Mr. 12Volt, switch 5 is configured ON, but all others are OFF. I have seen posts that indicate the switch 1 must also be in the ON position for a PDK car. Is this setting (switches 1 and 5 ON) correct only for the most recent version of the firmware? Or does this setting also apply to earlier versions of the firmware?
- Is there a way to determine the version of firmware installed on the box prior to installation? I waited for the device to ship at the end of September assuming it would receive the latest version. Is there any way to confirm this?
Toby
#240
Basic Sponsor
The P2000 supports up to AHD720 type camera. Many work but we don't have an approved model.
The DIP 1 for PDK option was added in the recent MCU update. Make sure your unit has the update. Below is a link to the update page.
https://www.mr12volt.com/pages/p2000...ftware-updates
