Modify PSE switch to be always ON as the default
#76
However, the meaning of this DIY is that it can be switched as if it were a genuine function using the genuine center console switch and the water-proof coupler.
Unplugging the coupler is the simplest and least interesting method.
It goes against my engineer's spirit.
Wilsy67 (10-21-2023)
#77
Hello 997 / 987 Pilots!! ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Thank you for your patience.
![](https://www.soaristo.org/blog/image/230923/pcb09.jpg)
The first 5 of 10 sets of the PSE Control Kits are now ready for shipment (Pic.1).
If you are interested, please post in this thread.
(Do not PM me directly. I will PM you after your post.)
[Notice & Disclaimer]
1) Installing this PSE Control Kit requires some electrical and mechanical knowledge and experience.
(I do not respond to basic or easy DIY questions. Please refer to this article and will007's installation report.)
2) I rigorously checked all the PSE Control Kits before packaging using a pseudo electromagnetic valve (Pic.2). Therefore, you cannot say that it does not work after installing.
(In that case, there is a problem with your installation.)
3) I will not be held responsible or liable for any damage caused to you by installing this PSE Control Kit.
(Engine failure, vehicle inspection failed, vehicle fire, etc.)
4) You are not permitted to reverse engineering or make counterfeits.
(The microcomputer program is unreadable (protected), though.)
I hope that your car life will be even more enjoyable.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
________
![](https://www.soaristo.org/page/post/signature01.jpg)
Blog: www.soaristo.org/blog/
SOARER (LEXUS SC) + ARISTO (LEXUS GS) = SOARISTO
Audi R8 V10 5.2 FSI quattro S-tronic MY2014
![](https://www.soaristo.org/blog/image/230923/pcb10.jpg)
________
Wilsy67 (10-10-2023)
SOARISTO (10-10-2023)
#79
Hi I would like to buy one of these please?
#80
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Hi 997 / 987 Pilots!!
Thank you @kellen, @Wilsy67 and @OmairK.
I sent you a PM.
Regards,
________
![](https://www.soaristo.org/page/post/signature02.gif)
I sent you a PM.
Regards,
________
SOARISTO (10-14-2023)
#82
Mr. @will007, thank you very much for this matter.
Of course, I would be happy to add you to the list.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
All 5 kits are sold. Thanks.
________
![](https://www.soaristo.org/page/post/signature03.jpg)
________
SOARISTO (10-16-2023)
#84
Hi Wilsy67,
I was relieved to hear that the PSE Control Kit had arrived.
The links to the installation instructions are (1), (2) and (3).
Let me know if it works on your Porsche.
All the best.
________
Weekdays a Businessman, Holidays a Mechanic, Sometimes a Poor Racing Driver.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
![](https://www.soaristo.org/page/post/signature04.gif)
parts arrived today, thank you very much 👍
can you please send me the link to the installation instructions, I want to print these out.
amazing quality of kit, really well done. Thank you again,
All the best.
________
SOARISTO (10-20-2023)
#86
Hi @SOARISTO , please add me to the list for next batch! Looking forward to retrofit PSE on C2S. May build out with an IoT project using this device to switch automatically based on geofencing or custom CAN parameters.
#87
Hi,
seen your instructions and was just wondering as the PSE cables were already connected at the plug end would it not have been easier to just cut the cables splice them rather than removing & reinstalling?
thoughts?
thoughts?
Been searching the forums here and other places and have yet to find the answer. Have a 2011 Spyder 987.2 and has the PSE. Would like to have the switch work so that the default is the PSE is in ON mode (light on as well) and I need to press the switch to turn OFF. I'm thinking it might be as easy as moving a couple connectors. From what I have read, on the 996 the switch actually worked the way I described -- Default ON, push button OFF.
thanks!
thanks!
#88
Hi bajabluejay,
Yes, I do.
That's a great idea!
![](https://www.soaristo.org/blog/image/131013/canscanner02.jpg)
Exactly 10 years ago, I made a circuit board, called "CAN Scanner".
![](https://www.soaristo.org/blog/image/131013/canscanner08.jpg)
And I tried having a conversation with my Porsche. Refer this article.
![](https://www.soaristo.org/blog/image/131013/canscanner11.jpg)
I think it would be interesting to control PSE based on various data from the vehicle.
Or based on data from a external GPS logger, you might be able to turn the PSE on and off when you approach your garage.
________
![](https://www.soaristo.org/blog/image/131013/canscanner03.gif)
![](https://www.soaristo.org/blog/image/131013/canscanner07.jpg)
![](https://www.soaristo.org/blog/image/131013/canscanner04.jpg)
________
#89
Hi Wilsy67,
I think so.
My kit is intended to be installed without any PSE, so new cables need to be routed. If the cable is already installed, it is better to use the existing cable.
Be careful of signal disconnections and short circuits when you cut the cables.
________
________
#90
I was reading will007s instructions, I was hoping Porsche had the cables pre installed for future use. 🫰🏻
Hi Wilsy67,
I think so.
________
I think so.
________
SOARISTO (10-21-2023)
