New use for the (useless) Sport Chrono clock
The following 2 users liked this post by PV997:
Henrik964 (12-22-2021),
Murphey997 (12-24-2021)
Thanks for all the nice remarks, I take it that it definitely doesn't look "ricey".
I would have preferred to use a color display so I that I could change the gauge colors to red when temps are too high, but I yet haven't found one that would fit into the VDO housing (and comes with nice looking fonts).
About productizing it: As I mentioned in my post, there's a CAN plug that plugs right into the Sport Chrono watch. IF that plug had carried PIDs 0x441 (Oil temp) and 0x245 (coolant temp), I would have been able to make a truly plug & play solution (total swap in less than 30 minutes)
BUT unfortunately that's not the case. Which means that I needed to route 4 wires (switched 12V and ground plus the two CAN wires) down to the area next to the fuse panel (it's a pain in the (lower) back, but can be done), but then I had to splice into the wires for the CAN bus, which is not for the faint of heart and that's where plug&play came to a screeching halt.
However if anyone wants to try it themselves, I happily share the parts list and the Arduino code.
dxrohanx (01-23-2024)
Very cool. Without taking the thread sideways, what should we know about oil temp gauge vs actual temp? I understand h20 temp gauge reading is intentionally "smoothed", but is the oil temp not considered accurate, or just in some cars or situations it isn't?
Likewise. I've been lucky that biz has been good and keeping me busy. Although, it's different working from home for sure.
It took me weeks just to get a system up and running. Things are settled into a routine again but for awhile there days just ran together.
I see Cloudspin also saw the same deltas: https://rennlist.com/forums/997-foru...l#post13638065
Karl.
Great idea.
I bought a 24hr clock to go in place of the Sport Chrono CLock.
Haven't installed it yet
Fitting a later year Macan or similar actual clock, would be a good option for us street folks.
But, it would need a timing signal, as it does have a manual setting ability, and I assume gets its signal from the CAN bus.
That is, if that silly second hand doesn't fall off...
Thanks for any tips!
I used to use Arduino controllers for quad copters, back in the days when you had to build your own, before they became hot consumer products. I never would have thought of using one in this manner. Really cool!
Impressive. Porsche has had a decade and a half now to make something useful out of this gauge that they surely must be aware is considered useless by most but have left it useless. Long shot and may be too late with your detailed description but consider getting a patent on this reconfiguration. Not that Porsche doesn't have smart engineers but you beat them to it coming up with a useful version of it. Unless they think the timer is just fine and they have a number of solutions like yours just sitting around.
So again, a long shot that Porsche would probably find a way around but just something I couldn't get out of my head. Probably because a friend of mine got a patent on a somewhat similar reconfiguration but on a completely unrelated item. Wasn't easy but a fight worth fighting. A gift that keeps on giving for as long as you're alive.
In the language of the statute, any person who “invents or discovers any new and useful process, machine, manufacture, or composition of matter, or any new and useful improvement thereof, may obtain a patent,”
https://www.uspto.gov/patents-gettin...ents#heading-4
Edgy01 (11-20-2022)
Any idea if the CAN plug for the SC carries any clock timing though?
The signals to the SportChrono clock are basically: start/stop/reset
I am only guessing here. But I don;t think that such a signal exists in a 997. The only clock in the car (the one in the cluster) is set manually, so there wouldn't be any need for the engineers to provide that signal. The signals to the SportChrono clock are basically: start/stop/reset
Thanks!
Your gauge above looks fantastic!!
Hatzenbach (06-17-2020)
Poseur
