Show your 997 Upgraded Steering Wheel
Old 09-25-2021, 08:06 PM
  #181
BHMav8r
BHMav8r's Avatar
Received 2,793 Likes on 1,769 Posts
Originally Posted by Petza914
Your oil pressure looks really high at idle for an oil temp of 200 or so and a normal water temp. I'm guessing your oil pressure sender has gone bad and is reading a couple numbers high all the time. Should obviously show zero when the engine isn't running. If it shows anything else, like 1.5 or 2, time for a new sender. If so, you'll need a ratchet and crowsfoot wrench.
Where is that, zactly ? My oil press reads 4.5 - 5 most of the time.
TIA
Old 09-25-2021, 09:55 PM
  #182
Petza914
Petza914's Avatar
Received 6,601 Likes on 4,197 Posts
TIA
Right hand side of engine bay (bank 2 side) up near the front.
Old 10-01-2021, 10:46 AM
  #183
Bwoy1981
Bwoy1981's Avatar
Out with the old...
In with the New! Loving it.
it was a very simple install, maybe took 20 mins. However my horn isn't working. I'm gonna look into it this weekend hopefully.
The following 2 users liked this post by Bwoy1981:
myw (10-01-2021), Spastblast (02-22-2024)
Old 10-01-2021, 10:51 AM
  #184
frybear
frybear's Avatar
Originally Posted by Bwoy1981
Out with the old...
I switched out my wheel for a newer style, probably a 991 or Macan wheel, horn works perfectly. Now...I have an older style wheel sitting in my office and when I took off the airbag...there don't seem to be any connectors inside the steering wheel that would connect to the car itself...does your have connectors?
Old 10-01-2021, 10:57 AM
  #185
frybear
frybear's Avatar
looks good
Old 10-01-2021, 11:49 AM
  #186
Bwoy1981
Bwoy1981's Avatar
Thank you! Yes my older steering wheel had connectors from the airbag to the steering column. I did connect the NEW connectors from the New wheel to the column, but no horn.
Again, this is a straight simple swap, no features on the steering wheel or anything.
Old 10-01-2021, 11:52 AM
  #187
frybear
frybear's Avatar
then I'm at a loss unless you want to remove it and reinstall? possibly the connectors weren't seated properly? It's also possible that you might need a new harness in the wheel but I am certainly no expert.
Old 10-01-2021, 06:46 PM
  #188
myw
myw's Avatar
turn *multiFunction wheel* to ON in the gateway module (via durametric pro/foxwell 530). the horn will then work. - even the dealers didnt know to do this until they were instructed to by their customers.
google prev rennlist threads on this topic to 100% confirm.
Out with the old...
frybear (10-01-2021)
Old 10-02-2021, 06:40 PM
  #189
Lantern Rouge
Lantern Rouge's Avatar
Originally Posted by arscottp
991.2 carbon non multifunction. I'm also in the process of adding some black to the sand. Really want black radio/ac bezels, air vents, and carbon cup holder trim. Just dollars...
love your carbon wheel. Did it start out with multifunction or were you able to source it without?
Old 10-02-2021, 07:10 PM
  #190
frybear
frybear's Avatar
not a fan of carbon fiber and yet I love your wheel! I changed out my wheel as well, but have the multi-fuction buttons which do nothing, so I have the manual blanks sitting on my desk...just not in the mood to remove the steering wheel again...
Old 10-05-2021, 12:02 AM
  #191
Diego Mintz
Diego Mintz's Avatar
Originally Posted by benznotmercedes
Momo Mod.07 350mm. Leather wrapped. Doesn't exactly match my sea blue interior but that's the problem with having sea blue interior. Pardon my dirty floor mats! Really makes the car feel more lively and my stock wheel was trashed/had a stupid steering wheel cover sewn onto it.
Hi! I´ve bought the same steering wheel for my 997 and I´ve been told that the Hub I bought doesn´t fit the 997, just 996. Can you tell me which Hub did you used to install your steering wheel? I will show the picture for the one I´ve bought:
Momo HUB
Old 10-05-2021, 12:07 AM
  #192
Diego Mintz
Originally Posted by J.Tan
I have the leather MoMo Mod.07 in mine. I absolute love it. It not only transform the look of the interior but also improve the driving position for me. The smaller diameter of the steering wheel also makes the steering feel a bit heavier which I like.
Hi! I´ve bought the same steering wheel for my 997 but the HUB that came with it doesnt fit the car, it seems it´s for a 996, not a 997, can you tell me which HUB part did you bought for yours?
Do you have a video showing your installation process?
Tks!!
Diego
I´m posting a picture of my HUB so maybe you can see the difference.
Old 10-06-2021, 07:10 PM
  #193
noahbeck102
2nd Gear
noahbeck102's Avatar
@GT2RSobsessed any chance you still have the original sand beige leather shift boot? Ive been trying to find one everywhere but they all usually come with a **** for a ridiculous price and I only need the boot.
Old 10-06-2021, 08:15 PM
  #194
J.Tan
J.Tan's Avatar
Tks!!
Diego
The MoMo hub is just a generic hub. It can work but it requires you to trim the dummy connector on the steering angle sensor.
The hub on my car is made by Works Bell. It's a standard length version specifically made for 997. I purchased it from Go Tuning Unlimited. It's plug and play with no trimming required It also comes with airbag delete harness with will prevent the airbag light from coming on and retain the horn function.
Old 11-24-2021, 10:23 AM
  #195
MrIncredible
MrIncredible's Avatar
I love this thread. It's inspired me to do this to my 997 now. I have a few OEM Carbon Fiber bits in my car (Shifter, eBrake, Cupholder trim) so I started looking at flat bottomed wheels on eBay with carbon fiber and alcantara and all that jazz, but after looking through this thread, I think simpler is better. These examples look soooo good that it's hard to argue getting too busy.
Versus something like this:
The following 2 users liked this post by MrIncredible:
myw (11-26-2021), vann81611 (11-24-2021)
Quick Reply: Show your 997 Upgraded Steering Wheel
