Chinese PIWIS clone
#346
I have a problem with VCI HSX clone, piwis2 always says injection is not ON. Recently I am trying to perform the commissioning of the headlights, in which the modules are initially programmed and then the injection switch ON and OFF steps.
The problem is that, not detecting injection ON, the commissioning procedure is not successful. I checked the pins of my OBD and I correctly detected that in pin 16 the 12V power supply is permanent, while in pin 1 the 12V power supply is switched under key as it should be. I don't know which direction I should go. Advice is welcome.
could that be the issue?
#347
You need a clean power source, since the 997 era a minimum of 40 Amps. Powermax and others make these, and some people also use computer power sources on ebay and adapt them to use in cars. Some people think they can get away with less than 40 amps to save money or something, but the factory manual specifies 40 amps. Newer cars as high as 90 amps
https://rennlist.com/forums/panamera...is-iii-64.html
JB
JB
#348
thank you for reply.
I am using a stabilized power supply 55A (Proxel 6055 NFAR) with costant 13,8Volt , battery icon in piwis is flagged OK , if i disconnect power suppy icon becomes in red .
I always used this power supply for programming/encode bmw group car without problem ....
#350
It's on cayenne 958 facelift year 2017.
Coding perform without problems ....
I hold power supply on costant 13,8V .
My power supply have volts adjustment about up to 16V….should i turn up the voltage?
i don’t have deep knowledge piwis.
But i don't know how many volt are required by piwis for this car…. 13V ? 14V ? 14,5V ?
#351
I was hoping someone could help me out. I'm looking for coding functions on my 997 GT3. I emailed Belauto and he had two versions of the software. I'm not sure which one I need:
38.250 Full Engineering + 38.900 (Taycan)
38.200.017 Full Engineering
Which VCI are folks using off Ebay and such?
#352
Any of those software versions would be great
The VCI you want is firmware version 1.6.6
Read more on this thread:
JB
JB
#353
FWIW, I had a faulty PowerMax 75A. I swapped out under warranty for the new 75A one with a handle and integrated volt meter aka PMBC 75A. It's 100 bucks more than the original one.
siberian
siberian
#355
Hi Anyone knows how do we enter the bios for PIWIS Tester 3 ? Mine is a China Version Clone. as i have the new HDD to install but was blocked by the BIOS Password.
I have tried many attempts on the password but non valid. Please assist
mine model is CF - 54DD005N7 ; 7FTMA36210
Sincerely request folks here for advices
#356
The Various Genuine OEM VAS systems I have all have a known password. I've never had my hands on a 'real' PIWIS, so I can't confirm what those passwords are.
I've removed various Panasonic Toughbook and Toughpad passwords using a method similar to the one found here.
https://gist.github.com/en4rab/55088...f3039e3c8ab6fd
In my case, I didn't care what the password was. I just blanked out the passworded area of the bios, saved it, and reflashed the machine with the newly cleared bios file.
Since this isn't an electronics forum, I don't think further discussion of how to read an EEPROM, hex edit files, or flash BIOS is appropriate.
Good luck!
#357
WMIC BIOS GET SERIALNUMBER?
#358
I bought a Foxwell NT530. It does a lot but can't read camshaft deviation or rpm history on my 986. Not impressed. I'm thinking I'll buy a PIWIS II clone rather than the Durametric.
#359
Maybe describe what you want to do with an analyzer?
PIWIS 3 is the latest with software v 40.7xx and VCI 1.6.6.0.
Launch, latest version does reset SRI and oil change light. Not as powerful but a lot more practical (handheld, no tether between ODB and unit, lighter and Search functions are available throughout). Lastly if you have several non P vehicles Launch is the choice.
siberian
siberian
#360
PIWIS issues with using current date on the computer, seemingly endless driver issues, a required dance of hooking everything up in the exact right order or it not connecting properly, constant software complaints if you don't hook the car up to a high-amp charger even if you need to do something quick, lots of cables dangling, etc. I usually spend FAR more time just trying to get it up and running properly than actually performing any given task with the PIWIS... I will ALWAYS reach for my Foxwell first to try and get something done and only use the PIWIS as a last resort. Perhaps I have a marginal clone box, perhaps I really need to buy the turnkey computer rather than running it on my windows setup, but as-is, I kind of hate using it.
Durametric falls between the two... More of a hassle than Foxwell, less than PIWIS. And I also really don't like that the Durametric will also sometimes appear to take care of something (like a service interval reset on my 991), but not actually do the reset. No error, no complaints, says completed, but the indicator is NOT reset, something the Foxwell handles with ease.
