When bore scoring isn't (997.2 bore scoring fear)
Now that I listen to it again, I think I agree, it does sound like it's coming from the drivers side cylinder bank.
just for your comparison purposes, here is mine. One video for each side of the car, not as close to the engine as your video however.
These were taken a couple hundred miles after I bought the vehicle. Doesn't sound any different today.
https://photos.app.goo.gl/u1XKsunwb4fBgrX86
https://photos.app.goo.gl/ofNCmSWYjDw8cXxZA
I bought it from a small dealer in CA that deals in a lot of water cooled cars. They bought it a few weeks before from the previous owner. Yes, I have contacted the dealer. He thinks due to the x51 pkg it is valve noise. I don’t think so but need to make my case, so I plan to have it scoped. Any other suggestions? Also anyone make a recommendation for where to take it for scope in Northern NJ?
Bodymotion 732 493-2700 Ace
DeMan Motorsports 845 727-9070 Blauvelt NY
EuroPerf Racing 973 773-4870 Bob Kakascik/JoeGarfield NJ
Protosport 973 839-5353 John or Paul
Power Tech 973 586-3210 Mike Rockaway
Thanks for the recs. I’ll keep everyone updated
Geez, I definitely hear a knock. I would try to return the car immediately, but that’s just me. If the warranty covers everything from a coolant pipe knocking to a new engine, then maybe keep it, but I’m skeptical of that. Regardless, those of you that have a knock that sounds like this, I would be checking the bore from top to bottom just to make sure.
SFZ GT3 (07-17-2019)
The high frequency rattly or ticking sound is the normal one - it's the DFI injectors firing. The slower knocking sound I don't think is a normal sound. Whereas bank 2 in the 997.1 motors is the side more prone to scoring with issues in cylinders 4 and 6, the 997.2 is the exact opposite with problems, when they occur, showing up more often in cylinders 1 and 3.
Definitely get as invasive as you can while the warranty is still in effect. Send an oil sample to Blackstone as mentioned. You're looking for aluminum ppm numbers in the single digits for a healthy engine.
Good luck.
Good luck.
this is what mine sounded like when it got bore scoring and the sound was coming from the left side just like yours.
https://www.youtube.com/watch?v=8CZsu-l7T2A
Thanks all. @bronz yes I agree similar sound with your last being a little louder. Trying to get it setup to be scoped. Bronz did you have yours scoped prior to getting it to Jake?
re: oil it was changed 5/1/19 and has about 100 miles on it - will oil sample be helpful?
yes it was an enclosed trailer. Looks like fluid of some kind leaked from another car.
No i didnt have it scoped, didnt want to waste any more money since i had metal shavings in the oil filter so it was pretty clear. Pull the filter and see if you can find anything in there, its really simple.
Thanks Bronz. Seriously guys thanks for all the responses and the responsiveness! Found a shop who will take the car today for inspection and scope the bores. Will report back
Good luck with everything---> Great that you have the warranty and perhaps even better if warranty was purchased thru dealer you bought the car from.
This probably doesn't help much but in the perspective of Moxy's post this AM - this is a pebble in your (anyone's) shoe.
I am keeping my son home today and we're going cloudbusting.
The following 3 users liked this post by MexicoBlueTurboS:
I'm hoping that it is just a water pump going south. Someone else posted a similar noise and since it was coming from down low and the driver's side, it ended up being a water pump. However, after listening to your video side-by-side with Bronz', it doesn't sound good. Regardless, best to eliminate the cheap/easy things first.
That's great that you have a warranty. You can probably pursue one of two options: return the car to the dealer or have the engine replaced/rebuilt. From reading here, it sounds like some of these warranty companies are a pain to deal with, so I'm not sure if a 30-day dealer warranty is underwritten by the dealer or a third party company. Either way, you'll need to be very assertive and have all of the evidence very well documented.
I'm hoping for a quick and relatively easy resolution to this so you can start enjoying your car. Best of luck and keep us posted.
z driver 88t (07-17-2019)
As you've probably read or heard, make sure they scope the cylinders by dropping the oil sump. Apparently cylinder scoring materializes at the bottom of the cylinder first and can not be effectively identified by pulling a spark plug at the top of the cylinder.
and Mexico - you are very right. Even worst case scenario it isn’t the end of the world. If it’s bad hopefully the seller will step up based on 1 month warranty.
MexicoBlueTurboS (07-17-2019)
