Newbie 997 maintenance questions
I am a first-time Porsche owner having recently bought an '07 997 Carrera S with 46K miles. Before I drive it, I want to perform (probably overdue) maintenance, and I am using the "Porsche Major Maintenance Checklist" as a reference. I am puzzled that two items are not included on the checklist, and I also did not find much info when searching rennlist.
- Is a radiator coolant flush/replacement not necessary under the 997 maintenance schedule (or is coolant only replaced together with a water pump replacement)?
- Is a regular fuel filter replacement not necessary?
If you search you will find a debate on #1 topic. Porsche used a lifetime fluid. Many don’t trust the lifetime declaration and choose to flush and replace. I chose this path with mine when I purchased it. It was an 05 that had original fluid in it.
Just change the coolant with the water pump. They sometimes last over 100,000 and sometimes last 30,000. 50,000 is what most people do it at as preventative maintenance, although mine has 86,000 on it. That will be a summer job.
As for the fuel filter. There really isn’t one. There is a screen over the inlet on the pump and it is a lifetime thing so nothing to replace there.
Replace the plugs and check to see if the coil on the top of the plug is cracked. If so replace it.
Tranny fluid needs changed too. Doesn’t matter if it is an auto or a manual. Manual fluid needs to be very specific fluid.
Brake fluid too.
Brake fluid too.
Welcome! I was in your spot two years ago. You will love it. But you cant intro yourself without a pic of the car :-)
I would replace the the pump and fluid. Water pumps on 997s typically need to be replaced every 40k miles or 5yrs. Also inspect the coolant expansion tank for any spider cracks. Ive got a couple writeups on these:
https://rennlist.com/forums/997-foru...ater-pump.html
https://rennlist.com/forums/997-foru...sion-tank.html
I would also replace the transmission fluid with Mobilube PTX. Thats supposed to be changed at 100k miles but my experience was this should be changed much sooner.
https://rennlist.com/forums/997-foru...-all-997s.html
If you are neurotic like the rest of us, you could also drop the oil pan to give yourself peace of mind you have no debris in the oil pickup.
Lastly, if you have any issues with the soft touch paint on the center console or AC switches, those are pretty straightforward to get sorted.
https://rennlist.com/forums/997-foru...g-results.html
doclouie and TheBruce - thanks for the info! I did not realize that the 997 does not have a fuel filter (you learn something new every day.....). Thanks for reminding me about the other fluids; I have them on my radar and they will be replaced next week. The links are very useful too!
Sorry about the picture-less intro - point well taken, though. I need to give her some TLC before attaching a pic.
Being new to this forum, I REALLY appreciate everyone's response and advice!!
Does the work on replacing water pump also apply to 997.2 PDK? I have faithfully followed Porsche's maintenance schedule but didn't see it mentions anything about water pump. My car currently has 47k miles.
Forgot to mention flushing the power steering fluid too. If you have a 4 there is also the front differential.
Get the LN Engineering spin on filter adapter so you can use a metal canister filter - this gets you a new bypass valve spring every oil change.
Get 2 of their magnetic drain plugs. One goes in your oil pan when you do the motor oil change and the other in the lower drain hole of the gearbox when you do that fluid change As TheBruce said - use only Mobillube PTX, not any of your other favorites - seriously. You'll have to mail oder it.
Get the LN low temperature thermostat too and install it when you do the coolant replacement with the water pump change.
Oh, and congrats - welcome to the group.
TheBruce - finally had the time to read your entire post with "60 Lessons Learned". It is absolutely awesome, contains an incredible amount of super-useful information, and provided helpful perspectives!
Thank you so much for taking the time to put this together (as well as your other detailed posts)!
