My car burned today
Technical Guru
Porsches (964, 993, etc.) have always had fire related recalls you just don't hear about them as often as you do the Italian fires. About 1000 MY03 996TT were recalled because the power steering pressure line was coming loose and dumping Pentosin all over the exhaust.
Former Vendor
Seeing that just makes me sick to my stomach...
Mike
Mike
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
yeah. The car was well serviced. Im checking on all the recalls.
I will post when I find out what the cause was. Just want to be sure first.
Did that make the news where you live? Sorry to see another wounded soldier. Glad you walked away. Who is the person on this board that sells Halon extinguishers at a reasonble price?
J
J
Performance Parts sells Halon fire extinguishers. I bought a 5 pounder for $229. Maybe it's overkill but at least I'm prepared. Other prices start at $103. for 1.4 pounds.
Folks I must give some caution here.. There are two issues.. One being the hose fitting and then the other being the actual power steering pump.
If the pump fails you also are at risk. However, you have a warning sign.. A high pitch squeel...
The pump issue affects all years..
I figured out who sells the Halon tanks. It's Gene, and he hangs around here and Pelican. i just bought a 6 lb. tank for $109 delivered. He agrees that a 2.5 lb. is just not enough if you really need it. He sends refilled tanks that operate fine, and if you need a refill down the road, it's real cheap too.
You can reach him at:
dcbvi@hotmail.com
Good luck....better to be safe than sorry. I've been carrying around a Kidde just to be safe, but I know that that kind of tank can cause more damage than good. This thread inspired me to get the right stuff.
J
dcbvi@hotmail.com
J
Every P-car needs a fire extinguisher and I'm not talking about a small one! Put the largest one in your car you can!! I suggest either a 5 or 6 lb. halon or halotron!!!!!!
