Bits & pieces lead to disassembly, Vareocam and on..
Here is another engine VarioCam pad replacement job in conjunction with an AOS. On a 00 Dual Row IMS stock 996 after having the classic puff of white smoke out of the tail pipes and all the telltale signs of a bad AOS, I decided to of course replace the bad AOS which did end up having a torn diaphragm. While I was doing that maintenance task I also decided to drop the oil pan and do an oil change along with replacing the oil filter as well then inspect for any debris. To my surprise I found these bits and pieces of Black and Brown plastic. At which point I then decide to drop the motor and trans to have a better look at what else was going on. My local Indi mechanic confirmed my suspicions that I had a worn down pair of VarioCam pads and he suggested the black parts might be from broken chain rail. That perhaps it would be best to inspect further and see. So I figured what the heck why not just drop the motor and have a good look inside.
The multiple black and brown pieces of plastic found at the bottom of the oil pan.
My ZF tip-Trans and motor coming down after a few hours of prep work. Good thing too because the transmission mount is also looking rough and in dyer need of replacement prior to re-install among other desired projects.
Up-close shot of the wear depth the chain has done onto the guide rails of the chain tensioner. Yes, tools P255 & P256 are installed.
The chain chewed up quite a bit of material on the pads, this explains the bits of brown plastic I found in the oil pan. Now to figure out how to compress the tensioner plungers without Porsche tool #9634. As the search for the source of the black particles continues. Already looked at the old AOS and all parts inside were there so on to the next suspect item.
Yep, those chain pads need to be done on pretty much every 996. Wear item. Done it on my previous one and will be doing them on this new one soon
Even though it's a wear item, I've observed various rates of wear between different cars. Some have worn down quite a bit vs others at various mileages. It's hard to determine what kind of oil change intervals, climate, type of driving, etc. plays into this.
It would be nice if we had some kind of inspection hole to take a peek from time to time.
AWDguy, thanks for the info and my indi suspected it was the Paddle plastic pad or the other black chain rail next to it. I checked what I could see of the oil scraper with the oil pan out and it's all complete. Going to open up the next bank this evening and see the wear.
Alpine003 I wonder if the upgraded ones have the same or perhaps better durability then what looks like to be the original pads.
Very easy, you just need to drop the engine .
Plus a bunch of special tools (that you can make your self)
Might take a week or two.
If the manifold bolts are seized on bank2 - prepare for passionate drilling
"prepare for passionate drilling"
This is what I say to the ladies in my life every once and a while.
I made a tool for compressing the vario pads using a quick release skewer from a road bike wheel the threaded end fits into the threaded hole on the vario system which compresses the pads , you need to place a metal tube over the skewer with a washer on the end so it doesn't damage the vario tensioner, as you screw it in the tube and washer push against the vario tensioner and release pressure from the chain, it worked for me, be careful though as I've heard some are left handed thread, mine weren't and this method worked great for me!
Upgraded pads are far more durable, material looks like nylon.
Here are some worn originals:
Thank you Byprovider, for the pictures of what the worn pads look like.
NOZ1974, I tried the bike skewer trick but seems as though my VarioCams are reverse threaded since the motor is a 2000 996, so I'm awaiting a reverse thread cutting tool to redo the threads on the skewer rod. Which does actually fits in the tensioner assembly perfectly
I also shifted focus to the IMSB while engine and trans are out. Bearing was the original Dual Row NSK with 100k on odometer and after removing the black seal there was no grease just engine oil in it with lots of play in all directions and minor abrasion on a few of the ball bearings.
