996 Forum 1999-2005
blown engine
Old 05-21-2016, 01:00 AM
  #571
Ahsai
Ahsai's Avatar
Default Engine Case Cleaned
See all the metal shavings? The cases came with a yellow tag saying you must clean the case thoroughly.
Metal shavings (expected).
I shine a light on the coolant return path. You can see the 3 holes where the coolant flows up from the cylinders and returns to the water pump.
Old 05-21-2016, 10:38 AM
  #572
Slakker
Slakker's Avatar
It's beautiful! So shiny. The Nickies look really solid. When does it start going back together?
Old 05-21-2016, 11:03 AM
  #573
ltusler
ltusler's Avatar
Ahsai,
What are your work benches coated with?
Old 05-21-2016, 11:06 AM
  #574
ltusler
ltusler's Avatar
And thanks for showing everyone what you get from the good old USA for your money, I wonder how it compares to work from Poland?
Old 05-21-2016, 11:30 AM
  #575
gnat
gnat's Avatar
Can we not drag that in here please? This is an awesome and detailed thread and would suck to get it interrupted with 5-10 pages of Martin vs Jake.
Old 05-21-2016, 12:13 PM
  #576
Slakker
Slakker's Avatar
I wonder what it would take to get Martin and Kibort soapboxing in the same thread. After the latter is back from a ban of course. But you are right, it would be vandalism to have it happen here.
Old 05-21-2016, 01:53 PM
  #577
ZX9RCAM
ZX9RCAM's Avatar
Beautiful!
Old 05-21-2016, 04:17 PM
  #578
Ahsai
Ahsai's Avatar
The next stage is filing and fitting the rings. Hope to be able to start assembly in June.
My bench came like that. It's some sort of anti-slip plastic coating. I like it.
Stock photos of the set I got:
Old 05-21-2016, 05:03 PM
  #579
911mater
911mater's Avatar
Good luck Ashai, thank you for your post,
Old 05-21-2016, 05:51 PM
  #580
rolex11
rolex11's Avatar
They were probably made in Poland.
Absolutely just kidding.....go on...
Old 05-21-2016, 10:35 PM
  #581
Ahsai
Ahsai's Avatar
Default Ring gapping
Time consuming but it's actually quite fun. I'm just doing some preliminary checking today so no ring grinding yet.
Old 05-21-2016, 10:49 PM
  #582
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
You paid attention in class to my 72 degree rule when doing measurements... It needs to be at 72 for 24 hours to normalize completely!
Old 05-21-2016, 10:58 PM
  #583
Ahsai
Ahsai's Avatar
Yes but being in the garage there would be some variation in a 24 hr window. I just want to get a feel and some reading today. Will bring the case inside the house and Set the thermo to 72F.
Old 05-21-2016, 11:05 PM
  #584
Ahsai
Ahsai's Avatar
Default Fish scale pulling the oil rings
Piston inserted upside down.
Oil rings only. Piston, rings, and cylinder fully lubricated
The scale I use. Works like a charm.
From left to right: oil rings, 2nd ring, top ring.
Old 05-21-2016, 11:20 PM
  #585
Ahsai
Ahsai's Avatar
Btw, despite the high quality rings, one of the top rings have burrs on its ends that would have scratched the bore. I deburred it and it's fine. Got to be really careful.
Quick Reply: blown engine
