996 Forum 1999-2005
Improved Clutch Action Dramatically
Old 07-18-2019, 04:04 AM
  #556
WrngCLD
WrngCLD's Avatar
OK I can't believe it took me this long to realize that you don't need to remove the entire bolt in order to swing the whole spring assembly down. As long as the hex portion clears it's head, that portion of the spring can be pulled out. With the clutch pedal depressed, there is an opening kind of like a C. I thought it was completely isolated within the black bracket. Go figure.
Pedal modulation is muuuuuch smoother. Not sure if my spring is damaged or just old, but there's no more sticky pedal feel. I didn't notice it being any heavier than with the spring on so maybe it was damaged.
Old 07-18-2019, 12:49 PM
  #557
808Bill
808Bill's Avatar
Glad you figured it out.
I went out last night to check mine in an attempt to help you and wound up pinching a muscle and then cramped up. At 6'1" with wide shoulders I'm going to pull my seat next time before trying to get under there! I think I have a broken spring but everything is still functioning.
Old 07-18-2019, 01:19 PM
  #558
WrngCLD
WrngCLD's Avatar
Lol definitely do your stretches before getting in there. Once I figured it out it took less than a minute start to finish
Old 07-18-2019, 01:56 PM
  #559
808Bill
808Bill's Avatar
Also, if you have aluminum pedals, put a sock or two over them!
Old 08-01-2019, 02:11 AM
  #560
ssgunny
ssgunny's Avatar
My CC was not working although the light would illuminate on the dash. I saw that the clutch pedal was not returning far enough to engage the switch. I bought the Home Depot (SKU 684838) spring that I saw suggested in another post to have on hand while I investigated. I removed the cylinder and noticed the much beefier stock spring had broke in half. I replaced it with the new spring and the pedal returns to activate the switch now so assume the CC will work now.
Old 08-01-2019, 07:48 AM
  #561
blacksquid
blacksquid's Avatar
Originally Posted by wrljet
That assist spring is also the source of a famous squeak.
Now if we could lose the power brakes and steering...
I tried a friend's BM E46 330i and the clutch pedal felt like a toy.
I don't know people can drive those things aggressively with such light controls.
Bill
Yeah, I've got the squeak. It's annoying and now I know how to correct it.
I also had the Clutch Delay Valve on my 2007 MCoupe! That was a bad piece of engineering.
Old 03-08-2021, 04:18 PM
  #562
arscottp
arscottp's Avatar
Bumping this thread.
Just found about about this and removed the spring from my turbo. 10x better. Everyone should know about this
Old 03-08-2021, 04:43 PM
  #563
Johnny DB
Johnny DB's Avatar
Same! I wonder though if the upper pivot point will be affected/wear prematurely because it's the only support now and has more side to side play...
Old 03-08-2021, 04:55 PM
  #564
TexSquirrel
TexSquirrel's Avatar
Received 2,423 Likes on 1,288 Posts
I just replaced mine. (It had been broken since I bought the car)
I'm going to have to get used to the lighter clutch, especially before I hit stop and go traffic.
I like the clutch feel with the helper spring.
It's going to be much better for my aging knee.
No more thoughts about a tiptronic swap.
Old 03-26-2021, 12:01 PM
  #565
brontosaurus
brontosaurus's Avatar
So I realize this is probably blasphemy, but I'm thinking about adding the spring back into my car as it's a GT3 and I also am plagued with a slight knee issue. I'm trying to use my glute to push the clutch more these days, but I'm thinking this would be helpful as well.
Anyone have a spare assembly they don't want that they'd like to sell me?
edit: nevermind.. these are cheap, I'm just going to buy a new one. I see PN 996-423-081-18-OEM. Is this the same for all 996, or does the Turbo have a different PN?
Old 03-26-2021, 12:20 PM
  #566
Johnny DB
Johnny DB's Avatar
why not order the GT3 part? If you order the Turbo you’ll be in the same boat/pedal effort as before
Old 03-26-2021, 12:24 PM
  #567
brontosaurus
My understanding is that neither of the 996 GT cars had the spring present. I should actually look under there
Old 03-26-2021, 12:32 PM
  #568
theprf
theprf's Avatar
Received 1,837 Likes on 1,170 Posts
The Turbo uses a different much softer clutch power spring - don't use the Turbo clutch power spring! It's designed for the power-assisted clutch on the Turbo.
The GT3, GT2, normally aspirated M96 powered cars, and even the Boxster use the same clutch power spring and that's the one you want.
Yes the 996-423-081-18 is the current part#. BTW, pelican is selling these at higher than dealer cost....
Old 03-26-2021, 12:34 PM
  #569
brontosaurus
Ahh, ok, thank you for the clarification! Much appreciated
Old 03-29-2021, 02:03 PM
  #570
Johnny DB
Johnny DB's Avatar
Originally Posted by nychase
Guys, you can easily release the spring by hand. It's a 90lb spring. It's easy to grip using both hands....and then of course the new spring is much easier. If you've ever used a "hard" grip stregnth trainer odds are it was 100lb...and that's just one hand.
Agree with this...use 2 hands and you'll be fine
Quick Reply: Improved Clutch Action Dramatically
