996 Forum 1999-2005
Hazard Trim Phone Mount
Old 03-09-2022 | 09:22 PM
  #46
Flyfishnick's Avatar
Flyfishnick
OK, now the silly question, does the hazard trim piece just pop out (something small to pry it) or does it require pulling apart dash??
Old 03-09-2022 | 10:14 PM
  #47
yaz996's Avatar
yaz996
Good question. ​​​​​​It takes less than a minute to make the swap. Step 1: Turn on the flashers. This reveals cutouts on the left and right sides of the switch button. Step 2: use a small screwdriver to pop off the hazard switch. Step 3: pry out the hazard trim (using standard trim removal tools or a larger screwdriver with the tip covered in electrical tape.
I'll add a video of the swap when I get back home.
Flyfishnick (03-10-2022)
Old 03-10-2022 | 02:57 AM
  #48
Flyfishnick
Thanks!!!! I look forward to it. Some things I can just make a real mess of, lol and I'd hate to go sideways on something this easy, hahhahahahahahaa (trust me, I can screw things up real good).
Old 03-10-2022 | 02:51 PM
  #49
jslev04's Avatar
jslev04
This is awesome! Definitely in for a Ram "B" sized (1") ball mount version!
Old 03-12-2022 | 06:26 AM
  #50
GmundtotheWorld's Avatar
GmundtotheWorld
I would like one in the quad mount, with the cord pass through, or one with a convertible quad/ram ball. Brilliant idea. Bravo.
Thanks much.
Von
Old 03-12-2022 | 01:16 PM
  #51
escreation's Avatar
escreation
nice design, I am in
Old 03-12-2022 | 07:57 PM
  #52
tj007m's Avatar
tj007m
Great idea!
Count me in for a couple.
Old 03-13-2022 | 04:11 AM
  #53
sweet victory's Avatar
sweet victory
In for a black ball mount when available.
I learned all about magsafe accessories this afternoon and going all in with my new iphone.
Old 03-17-2022 | 06:28 PM
  #54
driverx's Avatar
driverx
Cruisin'
Originally Posted by De Jeeper
then im in like flyn.
Very strong second here! Would love an aim solo II mounting option!
Old 03-28-2022 | 12:03 AM
  #55
yaz996's Avatar
yaz996
Received some magsafe mounts to test this week. The ESR and Rennline products both need a 17mm ball mount. ESR definitely has the stronger magnets. Rennline is more compact. Both seem like solid options. The Spiegel mount has the USB-C plug on the backside so it potentially could have been an even cleaner look. It uses a 15mm ball mount (no issue adding another version), but unfortunately doesn't offer a way to tighten by hand. Just from some in-kitchen vibration testing I can see the phone tilting down during normal driving conditions with that mount. Going make a couple design tweaks this week, and I'll try to have a cable routed thru the dash next test fitment.
Clockwise from bottom: ESR, Rennline, and Spiegel
Rennline mounted
ESR mounted
The following 4 users liked this post by yaz996:
Coussa (03-30-2022), golock911 (03-28-2022), Owain (03-28-2022), sweet victory (03-28-2022)
Old 03-28-2022 | 01:19 PM
  #56
sweet victory
I bought the ESR windshield mounted one ~2 weeks ago. It apparently is the strongest magnet currently available. That being said, it certainly seems bulky for the 996 and the blue charging light is not as discrete as I'd like it to be in the 996 interior. Love having it in my Tahoe though.
Old 03-28-2022 | 02:23 PM
  #57
Owain's Avatar
Owain
Rennline mounted
ESR mounted
Does the Rennline one stick out far enough for the phone to clear the vents when mounted in portrait?
This is a fantastic idea, well done.
Old 03-28-2022 | 03:04 PM
  #58
yaz996's Avatar
yaz996
Yeah the ESR is ridiculously strong. I was using the adhesive metal ring included with the Rennline Kit to make my Pixel 6 compatible, and had to add a layer a tape over the back of my phone to keep the ring attached to the phone. Planning to get a thick case to use with a buddy's iPhone for another test, and I have a magsafe case for my Pixel from Moment on backorder. If I ultimately make the switch to magsafe, the ESR will be going in my 4Runner.
Thanks. Both the Rennline and ESR clear the vents in portrait mode. Actually thought about going a few mms tighter to the dash, but that would have made it more difficult for getting fingers behind it when tightening everything up.
The following 2 users liked this post by yaz996:
Old 03-28-2022 | 06:47 PM
  #59
sweet victory
Out of curiosity, have you tried the apple mag safe charger? I would assume the OEM would have the "best" retention. RAM mount offers this; they didn't try to compete with a charger, so maybe Apple is the best? https://www.rammount.com/part/RAP-B-202-AP-MAGU
Another observation I noted with a coworker. My 12 pro "sticks" a lot better to the ESR than his 13 pro. We're both using an apple mag safe leather case; tried with and without the case. Not sure if this difference is noticeable between phone models vs phone to phone.
Old 03-28-2022 | 11:41 PM
  #60
yaz996's Avatar
yaz996
Yeah, I've been working on a B mount version. Was actually trying to integrate a ball receptacle (i.e. half of the short arm) into the hazard trim, but that has been a challenge. Just ordered an Apple magsafe charger and a couple RAM products.
Quick Reply: Hazard Trim Phone Mount
