996 Forum 1999-2005
UAOS install/tips/tricks
Old 02-25-2021, 02:07 PM
  #256
plpete84
plpete84's Avatar
Received 1,768 Likes on 902 Posts
Awesome mod!
Old 02-25-2021, 07:03 PM
  #257
nrp3
nrp3's Avatar
Originally Posted by abossana
F
homemade metal version. Drill out the plastic bracket and put a brass barb coupler in the hole. $2
What's the size? Is this a Lowes/Home Depot thing?
jobyt (02-25-2021)
Old 02-25-2021, 07:34 PM
  #258
jobyt
jobyt's Avatar
this is my kind of repair!
Old 02-26-2021, 01:16 AM
  #259
abossana
abossana's Avatar
I found this size to work the best. I found it at Home Depot but I’m sure Lowe’s or any hardware store will have a version that will work.
The following 2 users liked this post by abossana:
nrp3 (02-26-2021), plpete84 (02-26-2021)
Old 02-26-2021, 01:42 PM
  #260
Porschetech3
Porschetech3's Avatar
Received 4,564 Likes on 2,068 Posts
Eh, pretty nice piece if you use a fresh $6 Porsche bracket to put the $2 brass coupling into it.
I have seen the bracket break too often and all gets against the belt and causes more issues than a coolant leak.
The plastic is not a high quality and has no glass filler or other strengthening hence the reason it breaks so often.
I still recommend the URO Aluminum piece for $15-$20 bucks, no labor involved and will last a lifetime.
Old 02-26-2021, 01:43 PM
  #261
pcolapacker
pcolapacker's Avatar
Originally Posted by Porschetech3
To pcolapacker and 996.2 you shouldn't have installed the factory style AOS for ANY reason. The UAOS is superior in all ways , shapes, and forms, even in cost. You never have to replace it again, it protects against Hydrolock/engine failure by means of secondary oil separator and warning system, and is less expensive ( over time).
What's the price of the UAOS-CFN? Website has on back order and doesn't list a price.
Old 02-26-2021, 01:59 PM
  #262
Porschetech3
The UAOS-CFN is $460 + $30 shipping in USA = $490 total full Kit. Price will show up when comes off backorder.
Old 02-27-2021, 09:13 PM
  #263
plpete84
plpete84's Avatar
Well, finally had a chance to test my AOS. Huge thanks to Aaron (De Jeeper) for helping me with this. Definitely need to address it. Do I get a prize for the higher reading? Skip - you'll be getting a PM shortly!
Old 02-27-2021, 09:39 PM
  #264
TexSquirrel
TexSquirrel's Avatar
Received 2,410 Likes on 1,278 Posts
That’s not bad if you’re at a higher elevation.
But it is borderline.
Changing to the UAOS is always a great idea!!
Old 02-28-2021, 01:05 AM
  #265
De Jeeper
De Jeeper's Avatar
Received 3,392 Likes on 1,775 Posts
look again thats 60.1 not 6.01 inwc. I checked it several times. Seams very high, mine read 22 inwc when it was bad.
Old 02-28-2021, 07:15 AM
  #266
nrp3
nrp3's Avatar
Does your cap have that tiny extra hole drilled into it? I bought another cap, drill bit for the idle size, and the plugs, I just haven't been in a position to use it. I need to get a barb fitting too.
Old 02-28-2021, 08:46 AM
  #267
plpete84
plpete84's Avatar
We tested this in Delaware so hardly much elevation. Even at elevation this would seem like a sky high number. Regardless, it's the next job on the list.
Old 02-28-2021, 09:06 AM
  #268
nrp3
nrp3's Avatar
Assuming I understand the test correctly, that hole he has us drill would likely alter or lower those readings somewhat.
Old 02-28-2021, 09:27 AM
  #269
Porschetech3
That .110 precision hole is for testing blow-by "positive pressure" with AOS disconnected and plugged. See "Engine Health blow-by test" thread..
That -60.9 inh2o is extremely high and definitely indicates a severe failure of the AOS..
plpete84 (02-28-2021)
Old 02-28-2021, 09:32 AM
  #270
De Jeeper
De Jeeper's Avatar
Thx skip, fyi that same set up reads about -4 in my car with the uaos, so i know the tester and cap r good.
Quick Reply: UAOS install/tips/tricks
