Repairing the “black foam coming out of vent” issue
#271
997 Second AC Blend Door Repair
Thanks to all the excellent posts on repairing the old foam on the AC blend doors. I have a 2011 997.2 and just did this job including the second blend door. I wanted to offer a few tips I just learned to build on the excellent post from AMCPILOT.
1. As noted in prior threads, it is not possible to access the second AC blend door from behind the radio in a 997 (as AMCPILOT shows in his picture) - there is a bracket in the way
2. It is possible (as noted by AMCPILOT) to access the second door after removing the first blend door accessing from the frunk
3. However, it is VERY VERY difficult to remove the old foam and adhesive on the door, then position the new foam in place - the problem is getting your hands in there
4. As reference, I wear a size Small golf glove (Cadet) and I couldn't get my fingers on the entire door while the door was in any of the three positions
5. My wife has smaller hands and she could access the entire door - so I would recommend getting someone with very small hands to help with the job
6. One of those video probes was helpful to view back in the area but not absolutely necessary
7. I also ordered a hole plug set from eBay to just put caps in the holes but they didn't fit well enough to use (too small)
8. I used 1/8 inch Dynaliner foam (as opposed to Dynamat) as the replacement foam. I've had very good results with this stuff in the past.
9. Brake parts cleaner on a small cloth works well to wipe off all the gummy adhesive left on the door after removing the old foam
10. You can build some flexible angled attachments and duct tape them to your shop vac to clean out all the old foam pieces from the hard to reach areas
11. In order to place the new foam over the door, you can carefully cut out a template (using trial and error) that fits perfectly against the existing blend door to position the new foam perfectly before permanently pushing against the door
12. Then make some double-sided tape out of blue painter's tape to put on the template
13. Then place the Dynaliner foam piece (non sticky side) against the template
14. Practice putting this assembly in place a few times to get good at it - then pull off the protective backing and go in again, position perfectly and stick in on
15. You have to do this for both sides of the blend door
16. It will allow you to unstick it somewhat if you make a mistake, but once you push it on, it is stuck down pretty good
17. If you misplace it a little, you can cut the excess off the edge with a new sharp razor blade
18. Regarding the cap to cover the door hinge bushing that was cut off (as mentioned in prior threads), a 1/2 inch PVC pipe cap (non threaded) works well
19. For the cap, you have to cut a slot to allow for the heater core support to slide through and you have to wallow out the inside diameter of the cap somewhat so it slides on well
20. You can also drill a small hole in the side of the cap and self-thread a small wood screw through it. Then tighten this screw (just a little) to keep the cap secured
21. For overkill, you can paint the cap black and use some black caulk if you see any gaps - but avoid getting caulk inside the cap - only on the outside
22. To help reseal the foam panel flap that covers the heater core, you can scrape some of the tar-type backing off of some Dynamat and roll it into a thin line. Then add to the existing adhesive outline to get a better seal.
23. Note that these comments are in addition to ALL the other posts on this topic that tell you how to remove the heater core and perform the "through the frunk" method, etc.
24. Also note that my heater didn't work at first - I had to drive the car and get the coolant flowing well before it "burped" out the air that I had left in the heater core system. Then the heat started working as usual.
25. Final comment - this took a while to complete - having a helper with small hands and being patient and taking time to do the job right was the key for me - and it saved thousands of dollars!
First off, thanks to AMCPILOT for posting this content, super helpful. I recently purchased a 997 and the very first thing I noticed was foam shooting out the vents and what I can only describe as sound like pennies jostling around in dashboard. I took the car to a shop and was quoted $7k to fix the foam issue. Eff that.
I found this thread and was hopeful this was my issue, and got to work. Sure enough:
Excellent... after a bit of dremel work, here I was:
I was feeling pretty good until I read this entire thread and realized there is another flap that also might have issues that is not accessible without taking the entire dash out, or cutting up some the duct work from where the PCM lives, I thought maybe I could see if through the heater core opening and sure enough:
It was almost bare. Shoot, so I found some videos and FAQS on how to cut the duct work to get to it, and took a look if that was an option on my 08 turbo cab, negative.
I realized I could get my hands on that second flap, it wasn't comfortable, but I could do it, so I hooked up some jumper cables and moved the flap into it's three positions, great, I can totally get my hands on all parts of this flap.
You can see it moved:
Then I cut out some new new foam went in by feel only. I was able to totally re-foam this entire flap through the heater core cavity, I had to move the flap into the 3 positions so I could get it totally covered, it took a couple strips/passes per side, and it was a bit time consuming and slightly painful on the wrist, and I had to redo a couple of the attempts because I put it on crooked the first attempt, but all in all, it wasn't that bad. I was able to completely cover that flap all through that heater core opening without having to make any cuts, or remove anything other that the initial guide AMCPILOT provided.
And the good news, no more penny sounds coming from the dash, no more foam, and now not only does the heat and cooling work much better, I can actually direct it as well. woot woot! $7k saved!
Hopefully this is helpful for others looking to fix this issue[/QUOTE]
The following 6 users liked this post by FLA guy:
bk12 (10-22-2023),
bmchan (10-22-2023),
EVOMMM (10-22-2023),
lgyee4 (10-22-2023),
Projekt EPiK (11-07-2023),
and 1 others liked this post.
#272
/ Pedantry off. Now back to our regularly scheduled program.
wdb (10-22-2023)
#273
#274
Judging by the level of effort in all these posts, I think I'm just going to continue to pull the trapped foam out of the vents, and run the AC at all times to avoid the windows from fogging up for no reason.
My AC runs poorly anyway, and I need to see if something is wrong with the compressor (makes an odd low audible pulsing whine).
Could the lack of foam on the blend doors cause the AC to be rather worthless in 90f temps?
TN996 (10-23-2023)
#275
Template dimensions for smaller blend door
Thank you for the details for correcting the smaller blend door. Would you be able to provide the rough dimensions for the foam template (Step 11)?
#276
Yes! The larger door blocks off the heater core or evaporator core or vice versa. When the foam falls off the air just goes through. Fixing the main hvac door is not that hard, I just did mine following a video on youtube
QUOTE=Ben8jam;19072810]Judging by the level of effort in all these posts, I think I'm just going to continue to pull the trapped foam out of the vents, and run the AC at all times to avoid the windows from fogging up for no reason.
Could the lack of foam on the blend doors cause the AC to be rather worthless in 90f temps?[/QUOTE]
#277
Regarding the dimensions of the foam template, I wish I had taken a picture of the template. Using a combination of measurement and repetitive test fit, you can get it perfect using a little trial and error. From memory, it was about 7.5 inches tall and about 4.5 inches wide. Also, I cut 1x1 inch notches in the top and bottom corners of the vertical side that corresponds to the pivot point axis of the door. I did this in order to avoid any adhesive getting gummed up in the swivel hinges. Additionally, the outside edge of the door is wider by about 1/2 inch until you get about 1/3rd of the way up from the bottom. Then it cuts in by bout 1/2 inch and continues straight up to the top. This small cut in can be seen on one of the pix of ACMPILOT. You can also see it easily after you remove the first door. Also note that the first door is a little larger than the second door. And the first door effectively has two doors on different angles (as you can see from the pictures). One on each side of the pivot axis. The second door has only one door side flap that moves. When you cut the two foam pieces for the second door, keep in mind that they are mirror images of each other because they each stick on opposite faces of the door. If you make two identical foam pieces, one of them will be backward when you go to install it. The template works on both sides.
scm00re (10-30-2023)
#278
997.2 C2S small blend door template - used to repair black foam issue
The following 5 users liked this post by scm00re:
blacksquid (11-04-2023),
circuit.heart (11-04-2023),
FLA guy (11-04-2023),
hoster (11-03-2023),
wdb (11-03-2023)
#279
Do you have enough oil in the A/C system? Compressors hate being run dry, sometimes people recharge the refrigerant and forget that you have to put in a small amount of oil.
#280
How much quieter is the HVAC system with foam on the entire surface vs. only-over-the-holes? Or with the ebay 3D-printed plugs, or some kind of high temp non foam tape? I'm finally getting ready to do this and am trying to figure out the benefit of cutting the foam tape so accurately.
#281
golock911 (11-05-2023)
#282
I think you have that backwards. The smaller and almost "unreachable" one in the 997s directs the air to the windshield defroster. I did the repair on the easy to get one before I even knew about the second flap. Because I live in Florida, I immediately found out that did me no good as my windshield still immediately fog’s up. There is a reply above (#64) where someone went in through the heater core opening after removing the easy to get to flap and managed to re-cover this hard to get to flap. I’m thinking of going back in to try but there is almost no information about doing this second one on the 997’s. In Florida it’s a real problem with the windshield fogging up.
#283
For those of you that have installed the aftermarket caps vs tape/foam does it matter which side of the blend doors the caps are installed on ? I bought 2 kits to be able to repair my Boxster and 996 .
I don't think it would matter which side they are installed on but thought I would ask . I plan on using some kind of RTV or adhesive to hold the caps in place .
#284
#285
Peripheral question but does turning the system off close the vents? I found an acorn inside the lighter socket yesterday and three more on the passenger seat. Weren’t there a few days ago. Where the heck are they getting in? I already built a fence around the cabin filter which kept them from camping out there but they’re still getting in somewhere.
