996 Forum 1999-2005
What did you do to your 996 today?
Old 03-14-2020, 10:31 PM
  #2626
De Jeeper
De Jeeper's Avatar
Received 3,439 Likes on 1,804 Posts
Took mine to NJMP for a scda drivers day. Although it was in the 50s ot was a fun day with a good group. I was even able to pass a few cars by the end of the day. Sorry no track pics just a pit shot. Only issue i had was a hose clamp broke in the pit and caused me to dump some coolant. Luckily had brought some and topped off with water.
The following 4 users liked this post by De Jeeper:
Gingerman (03-17-2020), Mike Murphy (03-14-2020), Porschetech3 (03-14-2020), Ratchet1025 (03-14-2020)
Old 03-14-2020, 11:49 PM
  #2627
wyovino
wyovino's Avatar
Looks like you had a great day. I have the same wheels and love them. I bought them with a set of mounted winter tires years ago and decided to make them my year-round wheels.
Old 03-15-2020, 02:21 AM
  #2628
ssherman68
ssherman68's Avatar
I took the front bumper & air scoops off, cleaned out the condenser and radiator & replace the horns. Sadly the new horns didn’t solve the problem, When I put the fuse back in, they just blast non stop. The previous owner said he fixed the bushings on the steering wheel.
Old 03-16-2020, 03:21 PM
  #2629
mrfeh
mrfeh's Avatar
Woke it up from its 4.5 month winter slumber.
Started right up without any complaints at all.
Old 03-16-2020, 09:19 PM
  #2630
amargari
amargari's Avatar
Bought a hardtop off of eBay and picked it up. Got a good price on it. I now have winter wheels and a hardtop. I am prepared for year round driving.
The following 2 users liked this post by amargari:
atlcarguy (03-16-2020), Mike Murphy (03-16-2020)
Old 03-16-2020, 09:29 PM
  #2631
atlcarguy
atlcarguy's Avatar
finally started the paint correction on my speed yellow c2. front and driver side done. ill get some good pics when the weather is better, hard to see in the garage. really happy with how the paint is taking the correction.
az968gpw (03-17-2020)
Old 03-17-2020, 12:22 AM
  #2632
FLTWRLD996
FLTWRLD996's Avatar
Hit 100k today, thinking about taking it to a local indy for a check up soon
The following 4 users liked this post by FLTWRLD996:
atlcarguy (03-17-2020), az968gpw (03-17-2020), Gingerman (03-17-2020), Mike Murphy (03-17-2020)
Old 03-17-2020, 09:28 PM
  #2633
SoCal911t
SoCal911t's Avatar
Received 1,474 Likes on 712 Posts
Didn't do anything today but it looks like I'm going to have a lot of free time coming up to catch up on projects.
The word came down a little after 2:00pm from the GM's office and I'll be 'teleworking' for at least the next 30 days. I'll probably only be on the clock for 15 hours a week so that's 25 extra hours for wrenching.
The following 3 users liked this post by SoCal911t:
atlcarguy (03-17-2020), Gingerman (03-18-2020), Porschetech3 (03-17-2020)
Old 03-17-2020, 10:12 PM
  #2634
blazen244
blazen244's Avatar
Just had the windows tinted and polished the wheels up a bit
The following 2 users liked this post by blazen244:
*Eastep* (03-18-2020), Mike Murphy (03-18-2020)
Old 03-18-2020, 04:06 PM
  #2635
NE1N-11
NE1N-11's Avatar
What products are you using? Are you doing it by hand or using a machine? I've recently started researching so I can do a correction on my own.
Old 03-18-2020, 06:17 PM
  #2636
atlcarguy
atlcarguy's Avatar
i have a porter cable DA buffer, lake country orange pad and mequires 105 cutting compound. The Porter cable was like 120 on amazon.
I have used a bunch of different machines over the years, i have a bunch of stuff from groits but i have grown beyond their stuff.
pm me if you would like to chat, happy to give tips etc.
Old 03-18-2020, 10:36 PM
  #2637
ssherman68
ssherman68's Avatar
Just got the horn fixed! Since the PO said he'd "fixed" the bushings in the airbag retainer with no luck, I'd taken off the bumper to replace the horns. That didn't solve the problem. So I did some reading here, went to Lowes and got some #31 O rings. I took the steering wheel apart and found that the PO had put some red goo inside the bushings to try & restore them. No way I was getting O rings in there. I finally broke down and ordered a new airbag bracket from Pelican. Put it in today, put the fuse in (while holding my breath) and no horn blast. Tapped the horn and it worked!
Next up, I want to replace the coolant and the brake fluid. I need to decide if I want to do that myself or not. I think the stuff I need to buy to do it would approach the cost of having an Indy do it.
Old 03-19-2020, 07:56 AM
  #2638
JTT
JTT's Avatar
Awesome! Well done.
Are far as brake bleeding, it's super easy with one of these Far easier than the wheel work you just finished.
Coolant is also pretty easy, particularly if you follow Ahsai's brilliant procedure. It absolutely works a treat. You will need a
vacuum filling setup vacuum filling setup
though. The link is to a "good" one, but I picked up a cheap Chinese version at my local Canadian version of Harbour Freight , that works fine for the few time I actually use it.
The following 2 users liked this post by JTT:
Brian_C (03-19-2020), ssherman68 (03-19-2020)
Old 03-19-2020, 12:22 PM
  #2639
Mike Murphy
Mike Murphy's Avatar
Received 1,724 Likes on 1,071 Posts
If you use the vacuum method for replacing coolant, you will find that it’s easy and painless. However, be prepared to replace any hose you remove, as it could break or leak, although I did not have that problem on my 21-yr-old car.
Old 03-19-2020, 06:32 PM
  #2640
motoo344
motoo344's Avatar
I got my wheels back from refinishing. A nice surprise with everything else going on out there was honestly expecting them to get delayed a few weeks.
Quick Reply: What did you do to your 996 today?
