What did you do to your 996 today?
#1488
Sanded/polished out some scratches on my stainless steel door sills. Played around a bit with the process and different grit sandpapers (dry and wet) and landed on this simple process. The trick is not to polish too finely since the sill has a brushed finish to begin with. It shouldn't look like a mirror after. The 400 grit seemed to be the best match for the original grain.
1) tape
2) 400 grit DRY sandpaper on scratched areas; sand in the direction of existing grain
3) spray water and wipe clean to check progress
4) bar cleaners friend over the whole sill using a scrotch brite scouring pad (again in direction of grain)
5) spray water and wipe clean to check result
6) repeat until satisfied
7) take a few passes with the 400 again across the whole sill to even out the brushed finished if needed (again in direction of grain)
8) admire work
Didn't get mine perfect, as I got tired, but overall happy with the results.
1) tape
8) admire work
#1489
#1491
#1493
Replaced Engine Mounts and Oil Pressure Sender
Pretty easy job for both, 30 minutes for Oil Sender, 1 hour for Motor mounts including removing AirBox and Air Pump and replacing.
Sender purchase at http://www.RMEuropean.com OEM VDO sender
Motor Mounts purchased at www.RockAuto.com cheapest price for OEM Mounts.
Didn't need to jack up car, Just put block under engine, when resting engine.
Minimal tools required.m follow directions on Pelican Parts workshop instructions
Shift Feel is night and day better, Using GT3 Shifter which feels lots better now. Easy to select First. solid feel between gears.
old unit
new one being tighten w 19mm Crowfoot and 6 inch extension stubby ratchet
old mount gap space at least 1 " gap snap on stub screw driver slides in
New one Top Old One Bottom 3/8" hang down difference
no gap for screw driver now 1/2 inch max
2 old 1 new center
old unit
2 old 1 new center
#1494
New shift **** (delrin ****, aluminum shaft) from Lukas at FunctionFirst:
I'm a big fan of all of his products that I've tried.
I've wanted one of his shift ***** for a while now, but already had a nice aluminum Rennline ****. I finally decided to make the move.
They're on sale now, too, which I only found out after ordering. Bonus!
#1498
Pulled the gauge pod, the female receptacle for the hazards was in upside down. I pulled it out and tested and the hazards worked, put dash back together and turn signals worked. Horn still does not but that's easy to sort out. I'm amazed how interconnected the electrical is and the weird symptoms for simple problems.
#1499
I hate that switch, one my 3rd, Can't ever seem to get it out w/o breaking it. The Tabs never seem to release.
Interconnected, Oh yeah, ask people who have ABS/PSM light come on and it gets solved by replacing Brake light switch.
#1500
New steering wheel! Really nice LOVE the feel. Carbon and thickened where you want it. Flat on the bottom I was going to get a black airbag but I think I like the contraSt!
Bought from a fellow Rennlister. Awesome dealing with and real fast shipper! Thanks, SOLOW!
