993 Forum 1995-1998
View Poll Results: Who's interested in 3D printed door pocket reinforcements?
Yes
70
95.89%
No
3
4.11%
Voters: 73. You may not vote on this poll
Next 3D printing project.....Door Pocket reinforcements.
Old 04-15-2016, 09:33 PM
  #91
Todynot
Todynot's Avatar
I have a '96 C2 and they are exactly like GBX's.
Old 04-15-2016, 10:27 PM
  #92
gmorat
gmorat's Avatar
Hifi or no Hifi?
G
Old 04-15-2016, 10:28 PM
  #93
Todynot
Todynot's Avatar
Originally Posted by gmorat
Hifi or no Hifi? G
Hi-fi
Old 04-15-2016, 10:33 PM
  #94
gmorat
gmorat's Avatar
Has to be the difference then as I've gone through the option codes and nothing else makes sense.
G
Old 04-15-2016, 10:37 PM
  #95
Todynot
Todynot's Avatar
Has to be the difference then as I've gone through the option codes and nothing else makes sense. G
Makes sense. So what does that mean for us hi-fi optioned guys? Can you make a modified version that will properly fit?
Let me know if you need any measurements.
Old 04-15-2016, 10:39 PM
  #96
gmorat
gmorat's Avatar
You can measure it and send as many pictures as possible and I can look into it.
Old 04-15-2016, 10:53 PM
  #97
GBX
GBX's Avatar
Def hifi. The door panels are different but I always assume this part would be the same. Good catch!!
Old 04-16-2016, 02:57 PM
  #98
Rick-A-Shay
Rick-A-Shay's Avatar
Checked mine out and one repaired and the other ready to fail! I'm in for a set and my '88 has the same issue. If dimensions are same or similar, you may have a bigger market than you think!
Old 04-16-2016, 04:13 PM
  #99
gmorat
gmorat's Avatar
If my suspicions are correct, they should be the same but if you could have a look to check I would much appreciate it.
G
Old 04-17-2016, 02:19 AM
  #100
BesideTheBox
BesideTheBox's Avatar
G
I have an '86 Carrera. The profile on the door pocket is closer to the 993 Hi-Fi profile than the standard door pocket profile. But not identical.
It looked like the Hi-Fi reinforcement piece might fit if it had 1mm or so trimmed from 'shoulder' end of the piece.
The black surface inside the door pocket is fuzzy. I don't know yet if the underlying material is ABS or some type of pressed hardboard.
Above: Door pocket attachment area of '86 Carrera (screw is missing).
Old 04-17-2016, 05:51 AM
  #101
shiraz
shiraz's Avatar
Have been following both threads - Apparently I'm a hi fi guy. Hadn't known there was a difference, good that it has come to light before production of fix/ordering of parts. Really impressed with the effort & co-operation going into this from both parties. Both ( g morat & Beside the box) are gentlemen & scholars.
Old 04-17-2016, 09:14 AM
  #102
gmorat
gmorat's Avatar
It's not the hifi or the non-hifi......There is another design. Weird, you'd think that if they were redesigning it, they would have tried to address its fundamental flaw?!?
G
Old 04-17-2016, 09:21 AM
  #103
gmorat
gmorat's Avatar
We've now identified 3 versions(and hopefully not counting)
993 Hifi. BesideTheBox
Some 964 & 993 Non-Hifi. Mine
Some 964 & Earlier 911's. Neffets.
G
Old 04-17-2016, 11:07 AM
  #104
gmorat
gmorat's Avatar
So, this is the HiFi version as close as I can tell with the conversions of inches to mm. No way to know really without printing one up and test fitting. Anybody got a spare hifi door pocket or are close to Raleigh with a HiFi optioned car I can test fit on?
G
Old 04-17-2016, 11:40 AM
  #105
gmorat
gmorat's Avatar
Possibly this.....?
Maybe someday I'll get to sorting this out if I get a partner in crime to test fit. I'd prefer local of course as otherwise it adds to the costs and the iteration time. Gonna stick a fork in it for now. This last one was created by taking measurements from a scaled photo and cross checking them against measurements from WithoutTheBox's abs cuts converted to mm.
G
G
Quick Reply: Next 3D printing project.....Door Pocket reinforcements.
