Choice of engine oil
Not a good sign...what weight were you using? How many miles were on it? You might consider sending it off for analysis--its pretty cheap and provides alot of info. Several companies to choose from.
Justin
Justin
Brad Pit Shaun Penn - Have used in the last 3 oil changes.
Use to use Mobile 1 but changed after doing some research.
M1 is so expensive now. BP is better priced, but I can only find one shop that sells it.
It's an award winning drag car shop located in the sticks.
But I still drive there just for the oil.
I will stick with the Motul, have been running it in the car for years, and the engine condition is fantastic (100,000 km and about 80,000 km track). The tuner I use is a HKS Pro Dealer and only uses Motul in his personal and customer cars.
Miles on the drain interval? How old? Did you add any oil in between?
Blackstone can do an UOA for about $25. One test will tell you a lot, but not everything.
King of Cool
20W-50 is pretty heavy isn't it? I would think your cold startup oil circulation would be a little slow...
I used to run 20W-50 in my 64 Cadillac to keep the valvetrain from going clackety clack. On a cold morning it poured out of the bottle just a little bit better than molasses... but that was conventional oil, I haven't played with any 20w-50 synthetics.
Come to think of it you are right, the 75-90 synthetics are much more "liquid" than the old 80w-90 gear oils. I didn't think of that.
It's been a few years since I have touched dino oils, but that memory of turning over a 20w50 container then doing something else for a while as it oozed out of the bottle has stuck with me![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Just did a bit of reading and the JASO-MA oils have no friction modifiers. I would assume that a JASO-MB oil would be the best option for automotive applications, but who makes those? Does it matter?
