993 Forum 1995-1998
9m93 Speedster S #3 - Prime Time viewing.
Old 07-21-2012 | 04:26 PM
  #421
SuperUser's Avatar
SuperUser
agreed, perfection!
Old 07-23-2012 | 02:56 PM
  #422
David in LA's Avatar
David in LA
Originally Posted by RP993
...it's hard for myself to be objective about the car but it is simply gorgeous!!....
I completely agree!1
........The chassis is rigid like a coupe ( i had a 993 cabrio for 3 years, so i know it's torsion stifness limits), very tight in corners but also comfortable (thanks for the KW Var3i suspension).....
As part of the conversion, does 9M strengthen the chasis itself with reinforcements? Or is the increased rigidity due to the suspension upgrades? TIA
Also are the Techart painted flat black or semi-flat? Either way they look awesome....mine are painted gloss black and IMHO look meh
Old 07-24-2012 | 05:33 AM
  #423
RP993's Avatar
RP993
1. yes, 9m installed some special "top secret" reinforcments into the rockers, which gives the chassis extra torsion rigidity. It works really well, quite big difference to the "stock" 993 cabrio, not to mention the older and softer 964 chassis.
2. wheels: i guess it is semi flat. I would call it velvet black. Actually i use the similar Techart wheels on my 993 4S, it's gloss black and IMHO it looks also very good.
Old 07-24-2012 | 06:08 AM
  #424
RP993's Avatar
RP993
couple of days ago i got this picture from Marc:
Old 07-31-2012 | 06:01 PM
  #425
NineMeister's Avatar
NineMeister
Nearly there folks.
Over the last week the speedster hump has been painted, hardened, flatted off and polished.
Door panels fitted, gearknob and handbrake lever detailed and fitted.
Seats nearing completion, backs done this morning, bases were on the bench this afternoon.
Electric systems proving to be the Achilies Heel, HiFi head unit won't talk to the amp so now wiring out the amplifier, after which the ignition switch fails to power up the radio system correctly ....
Old 07-31-2012 | 07:08 PM
  #426
JPP's Avatar
JPP
OMG. The script in the shift **** and e-brake is Riviera Blue. Oh no you didnt'!!
Old 07-31-2012 | 07:32 PM
  #427
MielsOnWheels's Avatar
MielsOnWheels
Yep, he did
Old 07-31-2012 | 08:05 PM
  #428
H.H.Chinn's Avatar
H.H.Chinn
The painted blue inset lettering is a nice touch!
Old 07-31-2012 | 11:14 PM
  #429
UserA's Avatar
UserA
I have such a car boner.
Old 08-01-2012 | 03:51 AM
  #430
RP993's Avatar
RP993
Originally Posted by VA993Dreamer
Yep, he did
little but nice detail, isn't it
Old 08-01-2012 | 03:20 PM
  #431
AlvinSultana's Avatar
AlvinSultana
2nd Gear
Jeez...............no wonder they cannot get my car finished !
Old 08-01-2012 | 08:40 PM
  #432
NineMeister
Hump's underside painted black then fitted before Marc had a fight with the HiFi speaker installation.
Old 08-03-2012 | 06:28 AM
  #433
grahampeterm's Avatar
grahampeterm
If it ever stops raining - and work pressures allow, I must pop over in mine, and see #3!
Graham
Old 08-03-2012 | 08:46 AM
  #434
RP993's Avatar
RP993
Graham
and take some photos from the 2 beauties!
BTW: i will take the car on the 13.08 monday. Would be great to see you!
Old 08-03-2012 | 10:55 AM
  #435
Renoir's Avatar
Renoir
Amazing! Absolutely beautiful...
