993 Forum 1995-1998
Self Gratification with Pictures - Outlaw 993 - Updated with Dec 2010 Mods!
Old 12-12-2011, 06:45 PM
  #286
swmic
swmic's Avatar
Wow, that thing is a work of art!
Old 12-12-2011, 07:54 PM
  #287
Macca
Macca's Avatar
Heres a few more to keep the troops happy. The first one is almost a work of art!
Old 12-13-2011, 04:12 AM
  #288
trevor townsend
trevor townsend's Avatar
Thanks for the effort you have made in sharing your journey to what must be 993 "Perfection" with us. Inspirational!
Best for the Festive season and 2012
TT
Old 12-13-2011, 11:42 AM
  #289
V
V's Avatar
Wow man, serously nice work. You have about zero caliper clearance there
Old 12-13-2011, 11:54 AM
  #290
ryano
ryano's Avatar
wow... love the gas cap.
Old 12-13-2011, 12:16 PM
  #291
John Rygg
John Rygg's Avatar
Wow very nice.
more onfo on the gas cap please.
Old 12-13-2011, 03:34 PM
  #292
Macca
Macca's Avatar
Hi Guys.
Gas cap is a 997 exclusive item and can be bought from the Porsche dealer. There are two finishes. Matt and polished. They look nice on the car but in reality they are light and only made of thin pressed alloy. Its a bit disappointing that there arent any nice billet alloy alternatives. I have a brand new bright red factory one which Ill likely change back too now the photoshoot is done.
Good spotting. Rear caliper clearance is 5mm. Have never had a problem with this. To get such a deep dish on a non turbo bodied car rear wheel something has to give - and in this case its caliper clearance. There is plenty of clearance at the front however.
Thanks Trevor. Merry Xmas to you too....
Cheers
Old 12-13-2011, 03:58 PM
  #293
boxcarracer
boxcarracer's Avatar
Quick question:
You are running 265/35/18 on a 10.5" et54
What would your opinion be on wheels that would be 4mm more aggressive on the outside? Are your fenders rolled to their max? What camber are you running?
Thanks!
Old 12-13-2011, 04:13 PM
  #294
FisterD
FisterD's Avatar
Originally Posted by Macca
Final work includes installation of FD Motorsport ceramic coated mufflers stage II for a change - combined with the Dach X catless pipes these should sound sweet as the engine is wrung out on back country roads....
En route...!
Old 12-13-2011, 04:15 PM
  #295
Macca
Macca's Avatar
Hi. Im am running Bridgestone RE11 265. They are almost a semi dot tyre and have quite a cambered shoulder. With this configuration on a 10.5 x ET 54 the fender lips neeeded some mild rolling and I could get down to RS+10mm with no rubbing with a reasonably aggressive rear camber setting (over 2 degrees).
Since that time I have have the hubs machined to take off 3-4mm material. This gives ET 57-58 on a 10.5J rim. Now I can go RS -10mm with less aggressive rear camber and get no rubbing at all. Infact I doubt I would have had to have mildly rolled the fenders either with this offset. Same tires of course.
My advice. On a 10.5J rim 4mm more aggressive offset wont work without massaging the fenders considerably on the NB 993. If you are saying ET 56 on a 10J rim this might just be doable with the right 265 tire, some fender rolling and a big dollop of camber. But the most aggressive 10.J rim you can use would be ET53-54. The ideal would be ET 58-59 for looks and ease of fitment...reduce the offset below this and you'll loose alot of "dish" in the rear rim due to the need for caliper clearance...
Old 12-13-2011, 04:17 PM
  #296
Macca
Macca's Avatar
Thanks Darin. With the Dach X catless X pipes these really are the icing on the cake! Cant wait to heat the sound :-), the RSRs have served me well 10 years but its time to try something different...
Old 12-13-2011, 06:29 PM
  #297
ryano
ryano's Avatar
i cant wait to hear it too.... exactly the setup i am planning once i get the DACH
Old 12-13-2011, 10:31 PM
  #298
Macca
Macca's Avatar
Ryano. You will be very pleased. The RSRs with the catless Dach X sounded wonderful and I can only imagine the stage II's will sound equally as awesome if not more so. They are loud but just within acceptable limits. Stage IIIs may be a bit over the top without cats.
Old 12-14-2011, 06:51 AM
  #299
boxcarracer
Thanks for the reply. I guess I'll keep my 19" Ruf just in case this new setup won't work
Old 12-14-2011, 09:52 AM
  #300
gprosser
gprosser's Avatar
wow. wow. wow. late subscriber. hope santa brings the rest of the goodies (if any) you're looking for.
Quick Reply: Self Gratification with Pictures - Outlaw 993 - Updated with Dec 2010 Mods!
