993 Forum 1995-1998
OBDI circuit board group buy - ROUND 2
Old 04-18-2007, 04:57 PM
  #61
vuugti
vuugti's Avatar
SOB! I haven't been here for some time, so I'm in again if anyone doesn't know what to do with theirs.
Andy
Old 04-18-2007, 09:46 PM
  #62
Dudley
Dudley's Avatar
I am very late to this party. If anyone has an extra board or has decided not to build the kit, I am looking. Thanks
Old 04-19-2007, 12:38 AM
  #63
cowtown
cowtown's Avatar
For those getting close to testing, raycm (the circuit inventor) compiled a great thread with information about using Doug Boyce's ScanTool software on the 993.
https://rennlist.com/forums/993-forum/294027-diy-1995-obd-1-scantool.html
For you guys who still want to build it but don't have a board, it's relatively easy to do it on a piece of perfboard with wire-wrap, using the schematic in the link above. It's more involved than soldering the PCB, but that's how I built my first one and it worked out OK.
Old 04-22-2007, 12:16 AM
  #64
mmasse
mmasse's Avatar
Today I finish my first test on the car. IT WORKED!! I was able to read the code. There was only one code showing: 19 - Unknown Fault Code. Does anyone knows what this code is ?
THANKS A LOT COLIN!!!!..and all the guys who contributed to make this happened.
Old 04-22-2007, 04:18 AM
  #65
FlatSix911
FlatSix911's Avatar
Colin, I am now ready to test
Make sure the USB -=> RS-232 converter uses an FTDI chip and you should be okay.
My laptop PC does not have a serial port so I need to convert to USB - how do you identify the correct converter type? Mine says RoHS compliant.
Old 04-22-2007, 04:21 AM
  #66
Toga
Toga's Avatar
#@%&# ... Mine doesn't!
I'm 100% sure of my connection cables. I'll check the parts on the board. It's too easy to put a diode the opposite way... If anyone has a way to test the components when soldered on the card...you're welcome! ...definitely easier to land in rain with 35 knots x-wind!!!
I used a pmcia card with a serial port.
Mmasse congratulations
Old 04-22-2007, 01:43 PM
  #67
Toga
Toga's Avatar
Ok the afternoon is sunny, the beer is fresh but... My scantool4 fail to connect to COM1! Of course, I have only COM4 and 5 (I found that in the system file). No scantool file in my c:/windows either.
So I created a directory in windows called scantool. Then I created a ini file with [Comm Settings]
port=COM4. No way my scantool still want to connect to COM1!
How do you vchange that?
Old 04-22-2007, 02:55 PM
  #68
maurice97C2S
maurice97C2S's Avatar
It's in the readme ...
1.) As delivered scantool uses COM PORT 1.
This can be changed to another COM PORT #.
Look for a text file called "scantool.ini" It's likely in c:\windows if you're running XP.
Add the following to the file if you want to overide the default com port. Assign port= to
whatever com port you want:
[Comm Settings]
port=COM1
cheers, Maurice
Old 04-22-2007, 05:12 PM
  #69
Toga
Toga's Avatar
Yes Maurice, I read that but that file doesn't exist! And when I create it, scantool doesn't seem to care about it! So I'm stuck! A good night sleep and tomorrow I'll may find where the trap is.
cheers
JP
Old 04-24-2007, 02:54 AM
  #70
Toga
Toga's Avatar
I tried all what's written in the read me, but no way! I can't force that Scantool program to use another port than COM1!!!
Could somebody help in being more explicit about how to do it?
Old 05-24-2007, 02:06 AM
  #71
fredo
fredo's Avatar
bump
looking for someone with an extra board or interest in another run? I'd be willing to organize, provided we have a big enough group.
I'm willing to assemble too.
-frred
Old 05-24-2007, 08:35 AM
  #72
993Porsche
993Porsche's Avatar
Originally Posted by fredo
bump
-frred
+1 on another run.
Ken
Old 05-24-2007, 03:27 PM
  #73
911ron
911ron's Avatar
+2 on a board. Was out of town and missed the last one.
Old 05-24-2007, 03:46 PM
  #74
Coleman
Coleman's Avatar
+ 3 ON A BOARD for another run!!!
Coleman.
Old 06-20-2007, 06:33 PM
  #75
RicardoD
RicardoD's Avatar
+4 on another board run. Anybody doing this?
Quick Reply: OBDI circuit board group buy - ROUND 2
