[Engineering Explained] Porsche's New 911 Engine Is Absolutely Brilliant
#46
Important precision here, it is still a standard turbo in the sense where there is a mechanical shaft that connects the exhaust turbine and intake compressor. The particularity resides in an electric motor/generator that can either slow down the shaft to recuperate exhaust energy or accelerate the shaft to increase boost.
There is no need for a starter or generator, as the transmission-mounted 54-hp motor performs both functions. With vastly more power than a typical starter, the new GTS springs to life the instant the starter is engaged.
it's likely that little over half of this capacity, on the order of 1.1 kilowatt-hours, is used to promote long battery life. The battery has its own liquid cooling system to keep its temperature below 108 degrees Fahrenheit
he water pump has been moved inside the engine
I am sure this will be engineering excellence. But if something breaks, I would not want to be in the deal waiting room to hear the bill. The sticker shock would be shattering.
he motor-generator fitted to the eight-speed PDK gearbox. The eight-speed transmission arrays its gears on four shafts rather than two, making it more compact, front-to-rear, and leaving space for this e-motor
Thus --
DIFFERENT PDK
And fire, we all know about the lithium fires,
ince a hybrid such as this GTS is constantly adding and withdrawing energy from this battery—much more often than a PHEV and vastly more often than a pure BEV—it's likely that little over half of this capacity, on the order of 1.1 kilowatt-hours, is used to promote long battery life. The battery has its own liquid cooling system to keep its temperature below 108 degrees Fahrenheit.
Dont even think of the cost if this thing dies.
You do realize that all of this was a work around for a bigger NA engine brought on by the EU .. Porsche was heading in that direction in the 991.1 (power kit ) . NA engines scream and make you crave the upper range which is useful on the track or autocross but not as much on the street .
The hybrid will be much faster but the repair bill will cream the owner out of warranty and the complexity might just place him in a loaner more than he expected when it was covered .
Maybe I should have accepted that base car slot but we still dont know what the S , Turbo, and Gt cars are going to be . Thats what led me to just wait .
#47
I lost a lot of trust on this guy on his brake pad video which is basically an ad. That video is absolutely disgusting and he try to hide the fact that he is just being paid to promote a brand.
A while ago he also talked about how great PSCB is, and I have first hand experience on that and PSCB absolutely sucks. It squeal like crazy way more than PCCB and it is so expensive to replace making it cheaper to replace the entire system to steel brake.
Right now I just take his video as an entertainment, like any YouTube video. He like any other YouTuber would say whatever to get views.
As for the accusation that he's being paid to promote the brand, it's important to recognize that many content creators do receive sponsorships. However, this doesn't automatically discredit their reviews. In this video, he transparently discussed both the pros and cons of the brake pads, which shows a balanced perspective rather than just a promotional pitch.
It seems like you're defending your poor judgment by blaming someone else and dismissing his entire body of work because you disagree.
ap2danyo (06-19-2024)
#48
https://www.caranddriver.com/news/a6...ngine-details/
Thus --
DIFFERENT PDK
Thus --
DIFFERENT PDK
#49
dchang81 (06-18-2024)
#50
#51
#52
After watching this video, I have to admit that I have a new admiration for this new engine for the 992.2 GTS.
However, ultimately we will have to see how it performs in real life and how reliable it is.
I disagree with Ipse, though, that “every Porsche sounds like sh*t.” I reserve that label for things like Subaru 4 poppers with fart-cans in the back. Does the flat six sound amazing? No. But even with the stock exhaust, I enjoyed very much how my 992 sounded when I got on the throttle. Proper pleasing sports car sound.
It’s actually possible that this new hybrid flat six will sound better because it has one turbo instead of two. My only concern is if Americans will get stuck with the OPF filter.
Also, aftermarket exhaust makers have their work cut out for them with this engine.
#53
I quoted the source .https://www.caranddriver.com/news/a6...ngine-details/
Quote -- Instead of the twin-turbocharged 3.0-liter 9A2B6 used on the 992.1, the 992.2 GTS gets an 9A3B6 engine that displaces 3.6 liters; uses a single, electrically enhanced turbocharger; and is supplemented by a powerful electric motor-generator that shares the housing of the eight-speed PDK transmission—all operating on a 400-volt electrical system.
The exhaust is "fed" to the turbo
Quote --
This single electric turbo is larger than each of the old twin turbos, which were placed on either side of the engine. So Porsche engineers positioned the big turbo on the engine's right and used a crossover manifold from the engine's left bank of cylinders to feed exhaust gas to the turbo. The Turbo and its manifolding together weigh about 60 pounds, which is the same as the old twin-turbos weighed with their manifolds. exhaust is "fed": to the turbo.
#54
Sounds like the engineers did their job, the goal was lambda = 1, apparently they were already close to that goal with the 3.0tt. Seems like if you have no problem with the current 3.0tt motor then there's not much to dislike about this new one, even if my lizard brain finds going from symmetrical twin turbo to asymmetrical single turbo to be a strange packaging choice.
#55
#56
Thats not exactly it . It is electric .
Quote --
Quote --
The following 3 users liked this post by CanAutM3:
AlexCeres (06-15-2024)
#58
You should read up a bit more. There is nothing in what you quote that contradicts what I am saying, quite the contrary. As I posted earlier, the exhaust turbine and intake compressor are still directly connected by a mechanical shaft. The exhaust gases still mechanically compress the intake charge as is the case in a traditional turbo charger. The electric motor/generator simply adds or removes energy from the rotor depending on the operating conditions. See image below.
#59
It's not the "technology" it's the new system. The PDK coupled Electric Motor, the E-Turbo, the 400v system. the software that runs the system and the lack of soak time to mature all of the above.
In short, The idea will be fine, but this is a complex piece of software. and the new parts plus the system need to mature. How long ? My guess, probably 2 model years, not 1 and definitely not 0.
If you buy the new 2025 GTS I absolutely predict you will drive a loaner more than I do in my 2023 992.1 GTS.
I learned my lesson with the BMW N63 ... Never buy the first year or two of a big change
user 999993337 (06-15-2024)
#60
I purchased an X5 M60i as a daily late last year. It is scary fast.
