Cargraphic Valve Control Unit
Old May 23, 2025 | 09:31 AM
  #1051
APB-BOLO's Avatar
APB-BOLO
Originally Posted by arsenal55
Gotcha. My understanding though is that these will actually fully open the flaps regardless of engine state, whereas PSE fluctuates how open the valves are.
it will. but there seems to be 2 different ways the valves function on the 992.2. Everyone with the base says that the vlaves function like the .1 and rpm. however a few of us with S models have verified that when the car is in sport the valves are always open when the car is warm. to play it safe i would just let the car warm and throw it in sport and look in the pipe. if the valve isnt fully open install it. or if you plan to drive in normal all the time. install it
Old May 23, 2025 | 10:18 AM
  #1052
kevntao's Avatar
kevntao
not quite everyone...
Old May 23, 2025 | 03:47 PM
  #1053
CornerOffice's Avatar
CornerOffice
just before you install it. let it get warm and idle in sport mode. if the vlaves are open return the car graphic. if the arent put it on. seems base and S have different behaviors
Ewwww, huge chance of burning your hands or arms installing the valve controller with hot cats. 😖
Old May 23, 2025 | 03:57 PM
  #1054
APB-BOLO's Avatar
APB-BOLO
dude. you let the car cool........ feel like i didnt have to say that
Old Jun 26, 2025 | 05:18 PM
  #1055
chiapet15's Avatar
chiapet15
992.2 guys, thanks for sharing all of this. I took delivery of a 992.2 T last Friday. It's currently in the shop getting PPF/ceramic/tints, scheduled to come back home Monday. I have the cargraphic controller at home waiting to install. I was beginning to wonder if I was imagining things when cold starting in Sport / Sport Plus rendered no fun starts, but then a minute or two later the exhaust would come to life! I've also read that even with PSE, the exhaust flap varies in how much it opens depending on throttle input and engine speed. I'm expecting this unit to fully open the flaps at all times. I wonder if you can control them with the engine off to open the flaps before turning the engine over on cold starts.
@arsenal55 Just curious if you've had a chance to install the valve controller yet and if you noticed any differences compared to stock. On my stock 992.2, I notice that the exhaust valves open after a couple minutes and wanted to know if there was any additional sound left to gain by adding an exhaust valve controller. Thanks!
Old Jun 26, 2025 | 07:25 PM
  #1056
mdfud's Avatar
mdfud
This video shows installation of a Kies valve controller which is reportedly similar to the Cargraphic controller.
Old Jun 26, 2025 | 07:54 PM
  #1057
kevntao's Avatar
kevntao
the valve controller allows everything to be open all the time, my valves are essentially locked in the open state, even when the car is off. The 992.2 doesn't actuate depending on RPM's, it's open or closed based on the PSE button and some timer on start, I want to say the blue engine warming light is related here. I kept the controller because I'm too lazy to take it off and I like the louder cold start.
Old Jul 27, 2025 | 10:11 PM
  #1058
Cartod's Avatar
Cartod
edit: SOLD
I have a cargraphic valve control for a 992 Porsche for sale. $400. I put a tune on and no longer need. It’s like new.
Old Jul 27, 2025 | 11:21 PM
  #1059
C21ban's Avatar
C21ban
Great price and highly recommended, especially for those who are not doing a tune.
Old Aug 11, 2025 | 03:30 PM
  #1060
arsenal55's Avatar
arsenal55
Hey all. Just an update here hopefully to be of use to people. I have a 992.2 T (so PSE) for reference with Soul sport cats. I installed the cargraphic the day the cats got installed, and within like 24 hours, I was throwing CELs (bad exhaust valve). With the help of a local independent shop and my own OBD scanner, Soul, and Flat 6 (sold the controller), we all figured out it was a bad unit from Cargraphic. Flat 6 mailed a new one out, and it's installed as of Friday. Took the car out often over the weekend, and so far so good. To be clear, there are 2 modes. Mode A puts the flaps open fully regardless of whatever settings you have. Mode B merely puts the flaps on the stock settings. In other words, to fully close the flaps outright and always, you need Mode B and PSE off. I like it for cold starts but I get it's not everyone's cup of tea. Frankly, I've seen myself driving more often in Mode B. In some instances when I wanna hear it rip, Mode A.
Hope this helps. The unit works. FWIW, Flat 6 and Cargraphic said their new units have a firmware update to account for the .2.
Old Aug 23, 2025 | 07:25 PM
  #1061
ThrustNormal's Avatar
ThrustNormal
Hey guys, I see some of you have had trouble with Homelink functionality. I am having reception problems I think. The homelike actuation only works inside my garage(I'm thinking signal bounces off walls) when Im out on the road, it works maybe 5% of the time (the supplied remote works every time). Has anyone had this problem? If so what did you do about it? I'm using the new flimsy plastic mount supplied by flat 6. It is mounted right behind the oil fill cap per their instructions.
Old Aug 23, 2025 | 08:15 PM
  #1062
RotorOver's Avatar
RotorOver
Veteran: Navy
Just installed the Kies controller a couple of hours ago and had similar issues on my 25 T cab. I put the Kies open on link button two and that was working consistently in the garage. I put OEM on button three and it was inconsistent in the garage. Both buttons were inconsistent while driving. Kies mounts on the passenger side via 3M tape, but the .2 engine layout is different, so I had to find a different spot to mount it. But, it was still within 3" or so of the .1 location they used. I'm not sure there is anything that can be done. I'm taking it out tomorrow for a drive and will play with it more.
Old Aug 23, 2025 | 08:19 PM
  #1063
981KMAN's Avatar
981KMAN
Your location is right above the alternator which creates electromagnetic interference. I suggest that you move the Cargraphics Controller to the passenger side and mount it to the housing as shown in the image below;
Cargraphics Valve Controller install above engine electronics.
Old Aug 23, 2025 | 10:21 PM
  #1064
ThrustNormal
How come the supplied controller isn't affected by said electromagnetic interference?
Old Aug 24, 2025 | 12:08 AM
  #1065
981KMAN's Avatar
981KMAN
It is, yet due to its location being closer to the cargraphics unit, with less metal in-between, the signal gets through. Plus the Home link uses a directional antenna sending a stronger signal forward, versus towards the rear. The supplied hand held transmitter has an omnidirectional antenna, which sends its signal in all directions.
