Cargraphic Valve Control Unit
Mine is at the dealership right now so I'll have to wait til later this week to test again
could be faulty? my car is at the shop getting HAS. once i get it back my cargraphic will be thrown on and ill report back my findings
I installed one myself just yesterday but I think I have an ECU issue or "sticky" valves because my valves fully open with the controller, but cannot fully close when given a "return to normal" signal (i.e., when I close the valves, nothing happens. Valves are stuck fully open).
My car subsequently starts with a CEL, but is in "normal" mode and PSE works in the cabin -- I press the button and my valves open slightly, and they close slightly. Signals are being routed correctly it seems from the controller, leading me to think this might be a physical issue, or something beyond my ken with the ECU.
I can read and clear errors, so my CELs are just valve related due to parking the car with the valves "open" - and I have a high pitched whine from the rear of my car others have reported where I think the motor forcibly closes the valves.
I have done the following to troubleshoot, to no success:
1. Checked the connectors, all seem seated properly.
2. Performed 1 or 2 engine cycles (only installed for a day)
I will do the following to troubleshoot:
1. Disconnect and reseat all the pigtail connectors
2. Cycle the engine a few more times (i.e., give it a few more days)
3. Grease and lube the actuator shafts. Maybe they're getting physically stuck at 100% open?
Can anyone please let me know precisely how to do step 3 if it gets to that? "High-temperature Oil Lubricant of Valve Actuators for Dummies" so to speak - like even a brand of lubricant and best way to apply if all I have are ramps and basic handtools?
Here's a quick video I captured showing the different valve positions at idle after cold start between full open and PSE on. Maybe the 992.2 has the valves open more with PSE on than in the 992.1?
edit: nope, something definitely weird with my account
Here's the video showing the positions while the engine is cold and off. I didn't notice any change whatsoever in valve position across the 3 valve modes prior to startup.
Here's the video showing the positions with the engine running during and after the cold start.
When I have someone available to assist, I can try to get video switching between PSE on and off during the ~2 minute cold start process to see if the valves move at all, but based on the video it appears they're in the same position - fully closed.
These videos align with my experience in terms of sound and feel. Basically the first 2 minutes of the engine running from cold, the valves are totally closed regardless of PSE being on or off, of course unless the valves are opened via the controller. As such, there's an incredibly noticeable improvement in sound during the first 2 minutes of the engine running with the valve controller. Once the engine has warmed up a bit, though (seemingly at 160 F for coolant temp the valves open, but perhaps just coincidence the couple times I checked), you can see the valves crack open and PSE actually makes a difference at that point on the stock configuration. Of course, at any time with the valve controller active, the valves open completely. As mentioned in my earlier post, the difference is rather minimal between PSE on and valves fully open in my 992.2 Carrera, but I do feel there's a slight bump in sound and even feel at low RPMs. Could just be placebo, so I'd need some more refined, controlled tests to verify this claim.
Two final thoughts:
1. Perhaps the 992.2 has less of a difference w/ a valve controller in that it may open the valves more than the 992.1 with PSE on, or maybe it's the extra filter in the .2 over the .1 that renders the difference less noticeable.
2. I see a couple of you guys have mentioned seeing my posts in the email notification but not on the thread; I've had this issue for a while and it seems all my messages must be approved first. I reached out via the contact us form to see if I can have that approval dropped so my posts aren't significantly delayed for you all. Any other thoughts are appreciated!
Edit: Looks like my posts are going through immediately now 🎉
Last edited by Nicky1Finn; May 21, 2025 at 02:26 PM. Reason: Added note about post appearing immediately
