PIWIS 3 Codings ; RED speedo tip....
#47
You obviously have me confused with someone else No, of course not.
siberian
siberian
#49
Received 2,719 Likes
#50
Nah, oil, salmon, halibut and gold.
siberian
siberian
aggie57 (11-17-2021)
#51
Summary to date of mods:
1) Speedo color change
2) Rear lights on with DRLs
3) Logo login change
4) Passing flashes
To be worked on:
A) Determining headlight part number if modifiable with addition of ballast/igniter to matrix via Vehicle Order Form
B) Display time length after engine shut-off - my initial attempt under Kombi: Kodierwert: Displaynachlaufzeit from 240 to 60 seconds didn't have any effect so another parameter is no doubt needed.
C) I would DEARLY find a way to alter the wavelength of the front DRLs to yellow
D) When weather is warmer run a VAL with OBD rather than SERV as I can't leave the garage door open for 25 minutes by -30F
siberian
4) Passing flashes
To be worked on:
siberian
#53
Hi John and thank you but I don't do Siri (or her sisters/brothers) so for me the car is the infotainment.
siberian
siberian
#54
Another mod:
Disable driver seat belt alarm. I've been wearing them for over 40 years I don't need beeps and alarms to remind me...passenger side remains enabled (purposely).
siberian
siberian
#55
Can you disable the stupid passenger seat airbag warning? That drives me crazy.
#56
Yes, I haven't found where (well I've been busy... ) but if @John Mclane could chime in with a hint...
siberian
siberian
#57
Dash Board BOSCH PO68x 001 Gurtwarnung: Front Gurtwarnung Beifahrer nichaktiv
Dashboard BOSCH PO68x 001 - seat belt warning: Front seat belt warning passengee - not active
#58
siberian
siberian
#59
Anyone managed to
1) alter the passive wait time before manual input is required when stationary on Adaptive cruise control?
2) Alter the the time period on Lane Keep assist until it asks for manual steering input?
both of these things in my opinion are not long enough
#60
Concerning the disabling of the passenger seat belt sign, the step mentioned by @John Mclane alas doesn't work for (my) 2021 992; namely under Kombi PO68x 002: Warning config byte 4 39 (and 40) playing around with both those values and individually doesn't deactivate the lit sign. They could have changed it from the 991 or the 2020 model.
Matrix code removed as correct code entered as separate thread.
If anyone has managed to turn off this sign please post. Thank you
siberian
siberian
