PIWIS 3 Codings ; RED speedo tip....
#121
I've not tried, but need to shortly as I believe I have a corrupt 40.500 version, 38.750. Yes, E mode is preferable (haven't tried V mode).
1) Driver side Seat belt chime is easy. See attached
2) Unable so far to turn off ***. Easiest is to switch to Sport or Individual mode if you have Sport Chrono
3) Haven't tried the last one
Seat Belt Warning DISPLAY NO in Kombi
Kombi Gurtwarning selection
Codierbyte 00 Gurtwarning Fahrer NICHT AKTIV
Write and Save.
siberian
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/seat_belt_icon_display_2a31ab44a0b00fef0516b055606b6f27d2a1bc76.jpg)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/seat_belt1_ce779872fb31b09bf5687b362742683d82bd355b.jpeg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/seatbelt_f54f5adb3586fbb350309c88543e92b323fa660b.jpg)
Write and Save.
siberian
jfr0317 (03-27-2022)
#123
peterdouglas (03-28-2022)
#124
Start by checking the required code. You don't have it, doesn't matter if someone did or not. This has been covered before!
siberian
siberian
#126
Go to E Mode, don't think you need anything past v.38 for a 997 and read the various posts (especially in the Cayenne and Macan Forums) for coding.
siberian
siberian
#127
I tried 38.900 in simulation mode and it doesn’t seem to have as many options as 38.250 for a 992 Gt3
going to jump in tomorrow and make a few coding changes. Found the seat belt section
#128
Sorry I thought from your handle you had a 997. For 992 try v. 40.450 in E Mode
siberian
siberian
#129
So… it seems that the 992 has some sort of DME lock and the current piwis versions cannot disable A.S.S. yet. Maybe in a newer version. This is from our European seller of piwis.
I was able to use 38.250 in “E” mode to disable seat belts (thx to siberian).
going to tackle auto headlights next. Seems there’s a lot of info in BCM1
#130
*** is mentioned in over 30 modules IIRC. I tried a whole bunch of them with no luck but it seems possible as it is disabled in Sport Mode for example. I tried changing the tach color for example which is settable in VO and seemed logical as they're LEDs but no luck there either. Same for skins, some thought that the number of skins was tied to the number of FOBs or that it was only available for the 2022 models in any case struck out there as well. Lastly please note that what works on other models even 991.2s may not on the 992s.
Keep us posted
siberian
Keep us posted
siberian
