Got it. I don't think it's in the 2021 Kombi. I've been through it pretty thoroughly and I don't remember anything like that, but I'll have a look again. Given you have the red tach background is why you can't code the tach needle as you'd not see the tip if you coded it red as well.
I checked both v.38.250 and v.40.450.020 and I can't find any mention of a parameter that would enable you to display a full speedometer vs simply the tip. If someone does find it, please post. Thank you
Trying to centralize coding mods for the 992 here rather than in the Panamara Macan or Cayenne forums. No problem if folks object I can move it to wherever folks prefer or oven start a whole new forum for PIWIS3.
So first of course, thank you to @rnlst_log , @rainer , @FerdinandAG, Alex, @John Mclane, Terry...and countless others who chimed in with helpful suggestions and tips. It's been a long couple of weeks.
So to kick things off, since a few of the items I had on my bucket list have been covered in the Panamera forum and Cayenne (no doubt) here is a pointer to changing the speedo tip:
siberian
It is under:
Dash Board BOSCH PO68x 001--CodingProgramming--Kodiewert--Kodiewert: Weitere Kodierungen IV Tacho Zeigerfarble: weib/rot/gruen/tbd/tbd1/...
Check it out.
Remeber to: save then write it.
Edit: it was covered on first post. i think i am a bit drifted.
If you did do a WRITE then it should have changed the color as in the picture above. I can only suggest you find out the software version number and try it again as mine was instantaneous.
Thanx to @rnlst_log we managed to decipher this convoluted process.
Staring at KOMBI, the next 9 images show the steps (I believe) are required to reset the SRI. The last image does the actual writing to the vehicle resetting the "clock" or counters so to say.
Select what function desired: oil change, service...
Select Oil change or Service Inspection or both as needed. GetribeÖl refers to gearbox oil.
