Coding 992
#212
Originally Posted by 911topanamera
any new developments with coding John? Able to turn on GT3 shift lights? just got my 992, what cool things have you kept on? thanks
#213
#217
Originally Posted by John Mclane
Yes. GT3 has normal, sport, track.
I think I can make it work on the C4S. I found a couple of entrances for race mode (PCM entrance), but nothing happened, likely needing more modules.
When all was lost...
See the pics. Change the default menu to reduced. It activated the race and track options with the steering ****, not on the main display. The main display follows this: (steering wheel **** - main display)
Normal-Normal
Sport-sport
Track-Sport Plus
Race- Individual.
Wet mode only on the display.
Will drive and see what happens. I suspect it's all a GT3 gimmick.
#218
Normal-Normal
Sport-sport
Track-Sport Plus
Race- Individual.
Normal-Normal
Sport-sport
Track-Sport Plus
Race- Individual.
#220
Originally Posted by smiles11
So close John! I’d buy that tool in a heartbeat if it allowed us to add the track screen.
Sport response just shifts to "race - sport plus" for 25s (I changed from 20).
On the GT3 you can combine TC and ESC with the drive modes. More digging required...
#221
Haven’t read the whole thread, but is there a way to code out the passenger seat belt warning? In the 992 its way to sensitive. I had a 4 pack of tall boys sitting on the seat and it triggered the sensor.
#222
I turned off the airbag on/off warning in the 992, as it won't disappear unless you click on the arrow at the steering wheel.
Depending on the version, PIWIS coding capabilities are extensive.
surquhar (04-25-2021)
#224
Anyone tried it with Launch x431? I can't get anything modded that I can on the Macan. Woudl like to enable in Front End Electronics activate rear lights with DRL, passing blinker from 3 to 5 and seat belt. Thanx for any help
siberian
siberian
#225
siberian
