Coding 992
#196
Any fellow coders found where the instructions for the wheel **** are written? I want to check the available options, particularly if track mode is listed there-like on the GT3.
#197
Meaning there are some options not displayed?
siberian
siberian
#198
siberian
siberian
I think I can make it work on the C4S. I found a couple of entrances for race mode (PCM entrance), but nothing happened, likely needing more modules.
jfr0317 (02-20-2021)
#199
John, you working with PIWIS or x431? We need to create a compendium between then major analyzers to port what works on one and how to code in another - understanding that some items may only work on PIWIS.
siberian
siberian
#200
siberian
siberian
Still struggling when going module by module. I can get bits activated, major functions are tricky without coding from the options.
#201
I speak German so if something isn't clear PM me. The Launch x431 is tricky as well (coming from n years on VAG-COM) the stuff is mostly there but finding it is the hard part and then as you said linking the different options.
siberian
siberian
#202
siberian
siberian
Search didn't get me anywhere. It's possible that I need to search for German terms. I tried Rennstrecke, renn, and got nothing. So, if I find where those modes are written (wet, normal, sport, sport+), I may be able to activate the others. See the example on the picture.
Gormanlad (11-29-2021)
#204
I found race and track in the PCM options, but I think I need to locate the module that controls the wheel **** options. There's an option that allows you to control track mode from the PCM screen, wheel **** or both. I have the ladder activated but no results.
MrKahanna16, I would assume that's possible as it's a basic function going back years on VDub/Audi models.
siberian
#205
So from what I was able to decipher, RDK is part of the TPMS module and I would assume stands for Reiffen Druck Kontrolle so what is selected enables the track ball from the screen/PCM and from TPMS. I would assume that's on by default. As to German search terms for Wet: Nass, the rest are the same in German and English.
siberian
siberian
#206
Would this perhaps need a second sensor?
siberian
siberian
#207
siberian
siberian
#208
IIRC initial TPMS modules did have two sensors which is why I thought of it. So if it doesn't then there must be a module missing that's present in the GT3s as your display does show it but pressing it does nothing.
siberian
siberian
#209
siberian
siberian
#210
Alas I don't have a PIWIS nor for the moment a 992 so that's as far as I can go at this time. Please keep us posted and GL
siberian
siberian
