DSC Sport is Freaky
#61
Premium Sponsor
Bad news, we're temporarily sold out again.
Next batch is estimated to be completed mid-April.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
#64
Short answer is DSC Sport V3 controller pairs very well with progressive springs. Most OEM springs are progressive.
The longer answer is DSC Sport V3 controller varies the damping commands to each damper to the driver's input to optimize vehicle weight transfer regardless of the type of spring on the car(progressive-rate coil springs, linear-rate coil springs, and even leaf springs!), as long as the spring rate is within the operating window of the dampers, which all OEM springs are.
#65
How does one change which file is set? I might like to give the GT3 tour a go. And secondly, is it possible to have DSC mimic or otherwise copy the stock mode of a more fixed rate/model to run in normal mode, while Sport enables the DSC functionality? Essentially moving to only one DSC file.
#66
If you want a fixed setup I assume you just create a map with no compensations for G force etc, just a set value over the whole axis.
I have ordered one in the UK via a Porsche specialist, no idea if that made it out of the last batch - hoping it has so I can get it posted to me and I can use my time in lockdown to get it fitted and play with the software.
#67
Premium Sponsor
Premium Sponsor
Video # 105 "Reading & Writing" file.
#69
The info is available on the DSC Sport website. Here's the link- https://www.dscsport.com/tuning-academy/
Possible...but it will take a lot of time. And we will not support it since it's not our algorithm.
#70
Premium Sponsor
My pleasure to help. The calibration file is easy to change. Let me know how the GT3 "Tour" file feels. Save your current file before writing the new file.
#71
One last set of noobish questions. I'm sorry to continue to ask things, I promise this won't continue indefinitely. Under the tuning academy section of the site, I thought I saw a lesson 102, something about wifi connecting. That appears to no longer be up on the site. Is it possible to update the calibration file via wifi, or do you generally pop the unit out of the car and USB connect? And also, can you break up the files? Can you have GT3 tour in normal mode and Carrera T sport file in sport for example?
Lastly, do these changes require a windows based computer/connection? It appears so, but I thought possibly a wifi option would work around that and allow for an apple based setup.
Again, please excuse the questions during this introduction and setup. Really appreciate the feedback and time.
#72
Premium Sponsor
Using a USB connection is safe from being hacked. You can leave the cable connected to the DSC all the time and hide the other end of the cable under the floor mat until you want to use it.
In your example, since your DSC already has Carrera T file in it, and you wish to keep it the same in Sport mode,
you can open the GT3 Tour file, then go with Settings, then select you want to Write Normal mode(of the GT3 Tour file) to Normal mode(of the DSC), then use the "Write to DSC" button. See Settings screenshot below.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1344x816/dsc_setting_page_ed46def8bb3303f8be5548bb5666e83de4920ebb.jpg)
Yes, the DSC software was designed for use with Windows PC.
#73
Awesome. Thanks for getting back to me Tom. Really appreciate the responses. I don't have a PC at the moment, but hopefully I can find someone who does. Or maybe the next time I'm at Speedsport tuning they can plug a laptop in. Im sure those guys have worked with your product. For now I'll enjoy the programmed files on there. Thanks again.
Tom@TPC Racing (04-01-2020)
#74
the tricky part is to ensure that the USB driver bridge CP210x driver works on the VM platform - I can attest that this works for Fusion (at least) not sure about Parallels or Vbox, you could always try bootcamp and dual boot WIndows on your Mac - but that's probably more trouble than this approach
