DSC Sport is Freaky
when you compare the DSC price to other suspension components such as coilovers (even the relatively cheap Damptronics), springs, H.A.S, or swaybar
kits $12xx is not ridiculous for the transformative capabilities of the device.
Seriously, an aftermarket swaybar kit incl droplinks will set you back about
$14xx-$17xx or more, coilovers well even he B16's start at around $28xx ...
get your wallets out, DSC is great functionality for the $'s ... much better value than pretty much any suspension mod I can think of off the top of my head
you hit the nail on the head wrt PDCC vs non, effectively the sways on a PDCC car should be "decoupled" when driving in a straight line, so any vertical movement of the suspension that would normally be 'opposed' by the swaybar, thus increasing the effective spring rate, is not applicable ... so a PDCC car will feel "softer" than a traditional (non PDCC) car over bumpy roads...
So the key is to skip PDCC? I'm going back to test drive again and will report on findings. I have test driven 4 different 991.2s: C2, C2S, C4 and C4S. None of the cars that I've driven had PDCC and only one didn't have sport suspension. Felt the suspension was brilliant in all of them.
non PDCC car) will not contribute to the effective spring rate thus the ride
should be softer than a non-PDCC car all other things being equal.
This in fact is the whole/sole purpose of PDCC to provide the advantage of
swaybars/ARB (flatten body roll in cornering) while also avoiding the disadvantage of such in striaght line driving... that is additional spring rate (stiffer)
Nope, I am saying that with a PDCC car, when the swaybar are decoupled (usually when there is no lateral load on the car) the swaybars (unlike in a
I can tell you wholeheartedly that DSC + PDCC is great. There doesn't feel to be that much difference between normal and sport modes but both are outstanding. Also, I just had my front wheels set to 1.5 degrees negative camber. Seems to have helped turn-in a bit and I can feel the whole car in a nice way mid-corner.
DSC in fact subsumes some of the function of PDCC in as much as the DSC deferentially stiffens the outside shocks in a corner, similar to the effect of
PDCC coupling the swaybars and transferring the outside compression to the
inside effectively reducing lateral roll.
Yes, particularly when the car is jostling, jumping and skipping everywhere.
Thanks Larry! PM Sent.
My characterization is it's not harsh but it doesn't feel composed to me at all stock. With DSC it's much improved and my thinking is with a little suspension tuning, it will be perfect. Now the problem is going to be convincing myself to NOT get the tractive DDA R/T setup.
Well I have a .1 SPASM Carrera with PDCC and I don't find it overly harsh at all on even really bad roads. I'm amazed at how comfortable and composed it is, while still offering incredible cornering performance. Perhaps the softer sway bars in the PDCC equipped car is the key, relative to a SPASM car.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
OK, had to dig this up and add my enthusiastic support for the DSC Sport PASM module.
Finally installed mine in my Sport Pasm Sport Chrono 991-S - many of you know I've not been a 100% fan of sports Pasm not because of ride height (which I love) or scraping (which can happen even when you're careful in hilly areas like San Francisco) but because the ride on sh***y streets that our mayor refuses to repair despite economic boot time and our tax bonanza (don't get me started on impeaching d***head Mayor Lee!!) is terrible. The car is jiggly, crashes over potholes (with 20" CS wheels) and in general can cast a shadow on one's love for the 911 with its roughness (and I like a stiff ride in general)
Well, DSC all but fixes the harshness and ride issues with Sports PASM in cities or areas with un-maintained beat up roads!! Mixed driving around some of my normal roads - it's the same experience but 15-20% better in harshness - like you put on a great pair of hiking socks - not cushy but mutes the negative aspects of road feel.
I haven't had too much experience at/near the limit as my 911 is a weekend/fun run car, so I don't have a before/after to comment on the DSC in hard cornering or track work - but a little play on some twisties near me reveal the car stays planted and balanced. I believe what I've read elesewhere since the module is intended to improve handling at speed.
Hearty thank you to the DSC Sport team![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
- makes you wonder why Porsche left so much in PASM for the aftermarket to tune/fix but hey, I am a very happy customer so I am glad they did!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I was ready to swap the car for a non-SPASM until I was turned onto potential solution that is DSC. Plan on buying the Sport V2 Controller today and will report back my findings. If this works (and they get my sunroof to stop wiggling around) I will keep this car for a long time.
It should be noted that Porsche seems to have worked out suspension/chassis on 991.2 in such a way that it handles rough roads with ease, same firmness but with none of the issues described above, at least that's been my experience after a few test drives.
Chris- You have precisely explained here how I feel about the suspension on my 2016 GTS (SPASM+PDCC). It's not that it's too firm but how it handles bumps in the road both in a straight line and around corners.
On 19 C4GTS without PDCC, I find the standard spasm to be very compliant on less than ideal roads. I am always pleasantly surprised when going over some road surfaces that would have jostled me if I was driving in another car.
Basic Sponsor
Let us know if you would like pricing on one!
-Josh
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
i have a 991.2 S and, while it’s a fantastic car, I’m always looking for that little extra bit of handling and compliance on bad roads.
Basic Sponsor
I’m starting to become interested in a DSC. I know it’s a very complex controller and it’s a bit hard to imagine it could be better than what Porsche did but I’m listening.
Its not as complex as people make it seem. For the regular user, just swap suspension modules and done, boom, results right away. For the track heads and technical guys they start to play with settings and thats when it gets complicated..
-Josh
