PCM Issue with recent iOS Update?
#121
FWIW, I last drove the car (2015 GTS) on Tuesday and had not noticed any spontaneous reboots. I just returned from an hour out, and still looking good. Fingers crossed that I missed the bad update and it is now pulled and corrected.
Porsche_nuts (05-23-2020)
#122
#124
I have a '14 Panamera Turbo S that is stored in a garage where the XM Radio satellite signal is blocked. The car has been in the garage for the last week or so until I pulled it out today. Today I drove the car for about 90 minutes with no issue of the PCM rebooting. Everything in the PCM worked as it should. I'm hoping the PCM didn't receive the corrupt signal when it was stored in the garage and this issue has been averted. There may be hope for those of you that store your car in a location where the satellite signal is blocked.
Edit: Just to be clear I do subscribe to XM.
Pavegeno928 (05-24-2020)
#125
I did Info first. Just holding info does a quick reboot that doesn't clear settings. The handoff reset is what really clears everything and fixes the issue.
Not sure if it matters which is first, but I was successful with doing the handoff reset after the quick (Info button only) reset.
#128
Just a wild guess, but it appears that whoever was in charge of Sirius QA on this software push only tested it against later series PCMs and failed to make sure older series PCMs would accept the change.
Somebody needs to walk the plank for this one.
#130
My 991.1 is stored inside with a trickle charger and locked. I haven't had It out since before this started.
Anyone else in the same situation taken their car in the last 24 hours out and NOT have the issue affect them?
#131
Anyone else with a 991.1 S without any issues?
#132
#134
Took my car out for a 2 hr drive today. I had no PCM issues. Car has been in the garage since the Sirrius Virus started. Note: I never subscribed to Sirrius and I never took the free month listen, so maybe this has something to do with it?. But I have also heard that people have had no issues on the first drive, but then have had the virus on their second drive. I don't know why Sirrius or Porsche or whomever cannot send a fix OTA. They caused the problem, they should fix it.
