Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#736
I bought the NM Auto wireless carplay system from Nick, and I highly recommend it. One issue I've had is placement of the microphone. I tried to install it next to the steering wheel per the instructions, but I can't fit seem to fit my hands there. Does anyone have tips on the microphone installation?
Micro Microphone
#738
Can anyone show more pics/ideas on how to hide the joyeauto box? I think it wont fit under the air con unit. Anyone got tips on how to hide it on the passenger side? Also any tips on routing the red cable to the fusebox?
#739
The fusebox wire ends up being a bit short. I ran it right under the glove box, there is a cardboard type cover for the HVAC, I pulled that down, ran the cable up there and down to the fuse box. The carpet cover on the box pulls out towards the BACK of the car, with velcro on the front back of it. So pull the back (font of car) towards the center console, once the Velcro is off, slide the cover towards the back of the car, there is a snap on top that goes up towards the A pillar, and a long guide on the bottom. It's a little PITA.
Jasjeet Suri (04-03-2020)
#740
Pull back the carpet on the passenger side, there is a big bundle of wires I put the box to the right of that.
I also saw an option to fit it above the cold air bulkhead, which looks to come off with 5 clips. Any one do that?
When passing the cables through from the centre console to behind the glovebox, do I need to do anything specific or is it just a matter of feeding them through?
#741
I followed this video (5:20) for hiding the Carplay box (left footwell next to fusebox). I zip tied it in place. Great area because if you need to get at the Carplay box you don't need to take out the whole dash again.
I put the mic to the right of the steering wheel stalk like Sidvicous7. Much easier to run the cables there than overhead. Sound quality seems to be ok in that location.
Jasjeet Suri (04-04-2020)
#742
How do I remove the carpet?
Not idea what the "cold air bulkhead" is.
#743
https://www.youtube.com/watch?v=C5Hs...3&index=9&t=0s
diagram for passenger side carpet
KeithA (07-11-2024)
#744
I fitted it all today, was pretty simple!
Some pics to show what it looked like, and how i routed the cables to the passenger footwell, under the carpet.
Before
Make sure to enable this option, my Carplay audio didnt work. To get to this menu, connect via bluetooth to the PCM and select AUX - BT, then Options.
Config screen
Fuse box trim pops off
carpet pulls away
all in!
Before
Config screen
carpet pulls away
all in!
desmotesta (04-09-2020)
#746
#748
That’s a great idea TsaiCo. What is so ironic while conducting the install at TsaiCo home yesterday a fellow 50th owner I met almost four years ago at the Auto Club Race Way happened to be walking his dog and stopped to chat. He has also expressed interest in the CarPlay Kit. Keep me posted TsaiCo.
#749
Here is one bug/issue with the joyeauto unit. It is running when you hit Navi. So when you use the right **** on the stereo for scoll/navigation and confirmation of items in the UI, it is also controlling the PCM Nav in the background. So, I ended up setting the PCM Nav to direct me somewhere whilst using CarPlay. To get over this, i muted the PCM Nav's voice, so even if the PCM Nav engages whilst using CarPlay, you wont know/hear it. If you use touch screen, then its all OK. But for some items its much easier to use the PCM Stereo **** to navigate, since the PCM 3.1 touch screen is pretty crap.
#750
Mine does not do that.
