Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#3332
I will try the reboot first. I am using it wirelessly. What is the best way to get ahold of Chstek?
As I stated before, this only happens about 1 in 20 times, so it will take several weeks to work through a few items.
Thanks for the ideas.
#3333
@Porsche_nuts As a suggestion you could message the manufacturer's support team to ask if they support OEM cameras. I can't figure out from your message if you already have an Erisin, or if you're considering the Chstek, but either way the support is reasonable and you should get an answer back from them..
#3334
Still waiting on an answer from Chstek, but I have queried another Android seller. He stated that factory oem back up cam can work with Android Head Unit but a certain connector is needed, and that connector is very expensive. Said it would be easier and cheaper to just buy and install an aftermarket cam.
https://avinusa.com/factory-backup-c...rsche-bmw.html
#3335
I did a search for OEM camera retrofit to see if I could get some insight into the video connector that goes to the PCM and I found this thread and the pics in this post https://rennlist.com/forums/981-foru...l#post14889285
It looks like the interface box plugs into into the car side of the quadlock cable and then has an output quadlock that goes into the PCM - so that does imply that the camera video feed is sent via the quadlock connector so it might 'just work' with the Android unit as it did in Zed's car, but there are no guarantees until someone tries it!!
#3336
#3337
Installing an aftermarket camera is easy enough, but time-consuming. I did it for the Cayman in about 5 hours. I found a way to do it without removing the rear bumper. No experience with the 911 though, unfortunately. There is a ton of YT content about it though. You can also get neat cameras which replace one of the license plate light units (has light plus camera) and these are easier to install. The upside of eplacing the OEM camera is that a good aftermarket camera gives a much better image. My wife's rear view is amazing (LOL) and way better than the rear view in the Panamera, which is a lot less clear and well defined.
#3338
I messaged Chstek as well as I am in need of a new radio after my PCM bricked. They replied back and said they couldn't guarantee the OEM backup camera would work. Not exactly saying "no" but I don't want to take a $550 gamble on it. I also reached out to Isudar and they said their full replacement head units work with OEM camera's and don't require any additional wiring. I think I may try the Isudar unit out if nobody can confirm Chstek or Erisin works with factory cameras.
#3339
Hmmm. I was going to ask Isudar as well but both Aliexpress and the Isudar website say they are out of stock. Definitely let us know if Isudar is the oem cam solution.
#3340
I can confirm that Isudar worked with the OEM backup camera in my Panamera. But it still retains the dreadful PCM display etc of course.
#3341
ISUDAR Car Radio For Porsche Boxster/718/918 PCM 3.1 2012-2015 Android 10 Multimedia Player Navigation GPS stereo Carplay wifi - AliExpress 34
#3342
This is the Isudar Android Head Unit, not the board that goes into PCM. It is out of stock.
#3343
that is the old version, they have a new one and it is in stock:
https://www.isudar.com/collections/f...40657380802642
it's available in 7" or 8.4" screen size but the larger one doesn't have buttons
#3344
#3345
Thanks for link. Says right on ad that it supports original rear camera! So, are you moving forward with purchase?
