Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#3316
That plug is for the FM antenna.
Not sure what your question is. Do you have the corresponding dual FM socket on your HU? If not, then you need an adapter.
If your HU has a DIN ISO connector (the black one in the image below), then you need a dual Fakra adapter to DIN FM antenna, something like in this image:
djdunzie (07-10-2024)
#3318
So for ChStek, rear view cam wiring is for 3rd party cams. No way to wire OEM factory installed cam, or did I miss it? This seems to be the case as you need to plug in the video rca into the HU.
#3319
That's a good question - has anyone out there got an OEM camera working with a Chstek/Erisn head unit?
@Porsche_nuts what OEM cables do you have, or is it not obvious how the camera signal gets into the PCM?
#3320
I did an install of Penhui (post 1719) but removed it because of a host of issues, including no connection to oem back up cam. I tapped into brown and blue/black wires with no good results. Support was bad and they just said that I need a third-party cam as the unit did not support OEM. Am willing to try again, but not willing to rip out oem cam and put in a 3rd party one. Zed reported that his Erisin worked with oem cam, but wonder if there are any others.
#3321
In the Panamera I have a totally different (and much more expensive) unit to those discussed in this thread (other than by member @Santirx who has a similar unit and who inspired me to fit the unit into the Panamera). It is a 12.3 inch widescren unit from Zwnav. In the Cayman, we have the Erisin as my wife doesn't want to disturb anything as it all works perfectly, despite me 'mentioning' the CHSTEK one or two times
I think your unit was an outlier and in our many PM exchanges, we never did figure out how to get the camera working. You may be right that the 'Erisin-style' units will only work with an aftermarket camera.
#3322
#3323
Zed, since it worked with your Zwnav, it obviously can be programed to work with oem cams. Wonder why manufacturers are not doing so. Assume it is that costly to do and would make life easier for a good portion of their customer base. But what do I know.
#3324
If anyone has an OEM camera and has made it work with the CHSTEK or Erisin units, now is the time to gain massive kudos by speaking up
#3326
@Porsche_nuts As a suggestion you could message the manufacturer's support team to ask if they support OEM cameras. I can't figure out from your message if you already have an Erisin, or if you're considering the Chstek, but either way the support is reasonable and you should get an answer back from them..
#3327
Gotta say, The Chstek guys on aliexpress have been pretty helpful, the only thing standing between us is time zones (and language barriers) \
Basically, i have the app called "CarBinLink" and its another form of apple carplay... but WIRED! When i loaded the app from the "126" menu, it had the option for "easy connect" which from past units ive had from other cars, is wired carplay..
I told them that the app is "unregistered" and shows a QR code. The Chstek tech guy im working with is forwarding it to the Dev guy to activate the app for me. It requires wifi (to activate) and when i plug my phone in, it defaults to that app!
Also, theyre giving me a partial refund for sending me the wrong unit. Which is nice because technically, i did buy this unit but asked for the other one...
Also, this unit sends alot more sound to the rear speakers (6125D)
#3328
Has anyone else been having any screen issues with the Chstek unit? Every now and then, when I start the car, the screen doesn't look right. It is scrambled up and off color. When it happens, it only is that way for 5-10 seconds then it clears up. Sometimes it is worse than others, but always has cleared up so far. I am afraid it might start getting worse. I would say that it happens maybe 1 in 10-15 times at startup. This photo is from yesterday. It is usually worse than this, but not always. I always have the unit in CarPlay, so it starts with the connecting to phone screen then goes to this screen. I don't notice the issue on the connecting screen, but that is mono color so I don't know if it is messed up also and I just can't tell or if that screen is fine.
When it happens, it looks like this or worse for a few seconds before it clears up.
This is what it should look like. This photo was taken within a second or two of the other photo.
So, I took several of the suggestions on here and this is what I have found so far.
Connections in back of unit seem to be fine. Everything was snug in place.
I took it out of loading on the CarPlay screen every time I start the car.
I didn't have it happen at all for a couple of weeks, so I put it back into autoloading in CarPlay mode. A few days ago, it happened again. I quickly put the car in reverse to activate the rear camera and the image was normal. I put the car back in neutral, and the CarPlay screen came back on and was still bad. I hit the home button, and the screen was fine, I then quickly put it back into CarPlay, but by this time the screen was fine. So, it seems like it is only happening in CarPlay for the first few seconds that the screen is on.
I'm not sure what, if anything can be done about this. Any suggestions?
#3329
So it doesn't look like a hardware issue with your screen which is the good news. And good detective work so far!
That means it's either software or network. Things to try
- Speak to Chstek support to see if they can help
- See if there are any updates for the system apps on the Chstek
- Have you recenly done a full reboot of the Chstek eg by pulling the fuse or the power and quadlock connectors? It's a bit of an IT cliché but it's worth trying a full power off followed by an auto connect attempt
- Do you have another phone you can try? I know it might be tricky to arrange, but a second phone would rule in or out your phone being the thing that has the problem, rather than something on the Chstek
- Can you reset the app you use to connect the head unit to your phone eg delete the app data and cache and then re pair your phone.. Maybe it will establish a more reliable connection
#3330
Update:
