Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#2491
BTW, I have used Nova launcher on my phones for a long time now and I love its customisability. For some reason, I haven't tried it in the car. I may download it to the HU and make a custom, car-oriented home screen. There isn't much you can't do with Nova so it would be interesting to try to design a home screen that resembles the OEM Porsche HU.
#2492
@ZedZed who makes the expensive unit in your Panamera? I'm curious whether or not they do a version for the 911?!
This is the ZWNAV official store on Ali: (I had to shorten the links with tinyurl - Ali links seem to be huge)
https://tinyurl.com/53tr2ww2
One of the main considerations when choosing a Panamera widescreen unit was that the choices for RHD cars is limited. Because of the way the unit integrates into the car, most have been designed for LHD. There is a bigger choice now than when I bought mine.
Some sellers even offer a dual widescreen version now:
https://best.aliexpress.com/?spm=a2g..._redirect=true
If that had been available for my car as a RHD unit, it doesn't take much imagination to know that this is the one I would have gone for, obvs - LOL.
This one looks pretty much the same as mine, and this design fits 'centrally' in the dash so it suits both LHD and RHD cars:
https://tinyurl.com/33axsetf
Another design for LHD only (they have to provide a new trim panel to accommodate the unit's design, hence you need to specify LHD or RHD
https://tinyurl.com/5n7dje57
It seems that Ali product pages' links can't be copied - the copied link always takes you back to the Ali home page for some reason. I bet the sellers love that!
#2493
Bl**dy thing - none of those links go to the right place. Bear with me while I fix it.
Ali Express seems to be having some site issues ATM. I can't access my order page or my wiosh list either. Sorry about the links.
#2494
#2495
Thanks for the link - they are expensive! Looks like they sell the "Erisin" unit for £440!
I think the tactic of these companies is to sell the exact same unit through multiple brands and at different prices so they can sweep up a larger number of customers
They have a buttonless unit for the 911 but I think (if I ever decided to change HU) I'd go for this CHSTEK unit that was mentioned a few weeks ago as I like the big screen and buttons!
#2496
#2497
My unit does not have a volume ****, so it is a minimum of two screen touches to change volume. If I had to do it again, I would get one with a volume ****.
#2498
So far I have been happy with "Ersin" like HU, but here are the issues I have or have run into:
- The extremely low volume level of audio messages (text message playback, Waze directions, google directions, etc..) on Carplay makes it completely useless. I believe this is a HU problem as I can use Carplay in my 2016 GMC Yukon with the stock radio and my wife's 2020 Lexus RX 350 with the stock radio, I have also used in multiple rental cars and the audio level of Carplay is fine. I will say with everyone of those exampled I plugged in my iPhone but since this HU does not support wired Carplay I cannot verify it is related to the wireless connection or not. I have turned up the volume in each app as loud as it will allow in its specific settings but I finally just gave up (also adjusting the app settings makes the audio extremely loud when I then use my iPhone in my GMC). I can make music from my iPhone play at seemingly good levels, but I am not much of an audiophile and the sound of my 911 is my music!
- The volume level adjustment dial on my steering wheel and the HU got out of sync on a long drive. The response was severely delayed, and when I overrode with the **** a few seconds or minutes later it would remember that I had use the dial and adjust the volume. I have not been able to reproduce. Cleared on next drive.
- The station display in the MFD, seems to work sometimes. If I am on that display sometimes it just works, most of the time it just has T000. I can change stations and when I change stations it works (most of the time). Would be better if it did just not work.
Much like ZedZed I keep my unit in standby. I have traveled and not driven the car for two weeks and never had a battery issue so far.
RwdConnor (04-24-2024)
#2499
Interesting, i turned off all the maps, radio, etc in the MFD just because i thought it wouldnt work.
#2500
https://www.aliexpress.com/item/1005...21ef1802SsQ8Nw
Takes about 5 minutes to install and works great. I installed the volume control section in the Panamera's overhead console - easy to reach and operate. Way better than messing with on-screen sliders.
Here you go @Porsche_nuts - this is what it looks like installed here:
#2501
The station display in the MFD is not supposed to work - that info came from the PCM, which is no longer there. I disabled that display in the Porsche settings menu (along with the nav map etc) so I no longer see a pointless display when I scroll through.
#2502
#2504
You could try one of these:
