Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#2341
Maybe im missing something in the settings.
I took the unit out and plugged the FAKRA cable in, i now have power to the OEM USB port in the glove box. However, still no wired car play. Kinda annoying.
#2342
RwdConnor (04-05-2024)
#2343
Just pulled this from the Erisin website
" CarPlay
- Built-in CarPlay: Yes, just connect your smartphone to this unit with Bluetooth to use this function
- Connection: Wireless
- Support Device: iPhone iOS 7.1 and above
- Unit's Screen Control Phone: No, but you can download CarPlay supported function APK to use and control"
If wired is not an option thats kinda annoying, but not the end of the world
" CarPlay
#2344
" CarPlay
" CarPlay
#2346
That's a real shame... but at least you have got yourself another USB socket as a consolation prize!
I'd echo what Zed said about bluetooth audio quality - BT5 audio Codecs are so much better than a few years ago I really doubt you'd hear the difference when driving cars like ours and TBH a lot depends on the source quality of your music e.g. is it compressed MP3 or lossless etc etc
Interesting thoughts here: BT vs wired (in the same DAC) comparison? | Audio Science Review (ASR) Forum
If you play around with the new DSP EQ that you now have access to then I think you'll find BT audio a vast improvement on the PCM 3.1
BTW did you check the build date of your Canbus app? If it is March 2024 then you have the latest - if not then you may have the bright lights issue without realizing it yet!
#2347
Ill check on the Canbus build date a little later. All i know is that the button to update it was greyed out.
ZedZed (04-05-2024)
#2348
You can use the AUX input if you really want wired audio - see connectors 7 in the diagram above
You'd need an adapter for the iPhone to give you a 3.5mm female headphone socket and then use a cable witrh male 3.5mm on one end and 2x male RCAs on the other.
But you wouldn't be able to charge your phone at the same time, unless you fit one of the magnetic wireless charging things (which is on my shopping list too) and then it should all work
#2349
For context, I am what some call an 'audiophile' (I hate the word personally). I have an expensive tube amplifier setup and a big collection of vinyl to play on my turntable. I also stream the high-res content from Tidal, via a semi-tube-based streaming device, to the tube amp. I've been involved in sound reproduction as a hobby, and for a time professionally, for decades. Having said all that, I agree with your comments above. In such a dreadful acoustic environment as a car, nobody will really care what source their audio is from because the small differences in SQ will be masked by ambient noise, poor acoustics, small-scale speakers etc. Even Burmester systems are still competing with the acoustic space in the car and the limited room for speakers and subwoofers. CarPlay via wifi will sound at least as good as CD or better, depending on the resolution of the audio stream. CarPlay via BT will sound good enough. Music off a USB will sound the same as from CD (assuming lossless files are used).
From an audio perspective, RWDC should enjoy his music greatly from wireless CarPlay. He will definitely enjoy it from a USB stick. But I can see his point - he prefers a wired connection and he ouight to be able to have it. <flame> If he swapped his iPhone for a decent Android phone, he could break free from the clutches of Cupertino and have wired or wireless to suit his mood, of course </flame>
The following 2 users liked this post by ZedZed:
Larson E. Rapp (04-06-2024),
#2350
"RWDC"
Im also a big advocate for Hi-Fi. Have an analog setup myself in the office.
I use apple music because spotify does not offer Lossless audio streaming... (Its 2024, cmon spotify)
I will have NO iPhone slander in this chat. I got an android headunit, is that not enough for you android guys?!
#2351
"RWDC"
It's a step in the right direction, for sure
ZedZed (04-06-2024)
#2355
I’ve seen OEM replacement options for 997 generation - but why is Porsche not coming out with a solution for 991.1? It would be a dramatic upgrade and make those cars so much more desirable (given NA).
https://newsroom.porsche.com/en/2023...ing-30885.html
Or am I missing an obvious solution that would allow a dealership to upgrade 991.1 with Porsche approved retrofit? Apologies if this has been answered before.
