ACF TT Kit, Inconel 625 Manifolds, Garrett G30-770 Turbos, Tial 44mm MVR Wastegates.
ACF Titanium exhaust full 3.5" to quad tip, recirculated gates.
Evospec 4.0L Built Motor and Stage 1 CNC ported head.
Evospec Surge fuel tank system triple 525's, lines, and regulator.
Evospec Custom wiring harness for Syvecs extras.
Dodson Clutches with billet oil pan and bracing.
Billet Intake Manifold with Port injection.
BMS Intercoolers with custom hydraflow clamps.
BMS Charge Y Pipe with Tial BOV with custom hydraflow clamps.
BMS 3.5" Intake with Do88 inlet system.
BMS 2 Gallon Stealth Methanol Kit.
BBI Roll cage.
BBS FI-R.
Syvecs ECU system tuned by Wayne.
Motec C127 Dash for extra logging and live data.
Added extras for fine tuning and safety.
- LPFP Sensor
- Coolant Pressure Sensor
- 6 EGT sensors (1/cyl)
- 2 Back pressure sensors (1/bank)
- 2 Shaft Speed Sensors (1/turbo)
Might have forgot some things, but I'll add to the list if it comes to mind.
The machined parts so far. Head flange for the manifold and throttle body adapter to Hydraflow clamp system. I'm not using any Tbolt or silicones for chargepipes in this kit.
One of the manifolds is completed. Inconel 625, 1 7/8" tube .035" wall thickness double slip merge collector. It came out to 6lbs
What an awesome build by one of the nicest guys to work with in the business. Can’t wait to see you break some records brother! You deserve it! Keep up the good work and updates.
Greg
Thanks Greg, I appreciate the kind words. You have a nice build coming up yourself it's going to be a violent beast.
Not going to be much of a race haha but i would be thrilled to get to line up with you. I will likely bring the M8 just to test it out so it will be fun to see you fly away. I've had the Porsche at 15+ half mile airstrip events so it will be fun to try something new.
Bring your turbo so that we can see the difference with the 4L engine build!!
Pardon my lack of knowledge but what does « building » an engine consist of? How do you make it stronger? Do you change the pistons? Do you redo the lining of the cylinder walls? I’m genuinely interested, as I plan on keeping my turbo forever and one day the time will come when my engine (or trans) will stop working. (I drive it A LOT). Thanks man and can’t wait to see where this is going.!!
The engine build consists of forged pistons, rods and they bored and sleeved the motor to make it a 4.0L I also have some thicker headstuds, CNC headwork done as well. The motor is rated good for 1500whp.
Presumably there are some changes made around the head gasket/water ports as well to handle such high cylinder pressures, or is the stock head/block interface situation good (which would surprise me)?
Thank you Payam by the way I love your intercoolers.
when you say sleeve the cylinder walls, it’s so that it can withstand the pressure? With something other than aluminum I suppose. Thanks! If you have pictures I’d love to see that!
I wish I knew exactly what they did under there lol. I just got the basic information and what it can safely handle. I'll see if they can chime in on what they did to my motor exactly for those curious
Thank you for the kind words, they definitely work very well with OEM fitment! Yes, it's sleeved with iron so it can take more pressure. I don't have any pictures of my personal block, but this is how a sleeved motor looks:
Finally got some more stuff done, progress has been a bit slow because we had to catch up on some retail/production items. BMS stuff always comes first no matter what lol.
Anyways, both manifolds are fully done and bolted onto the car. We're finished the driver side intake piping and chargepiping.
We cut down the compressor cover and welded a 4" Vband for the intake/inlet. Tapers down to 3" connects to the do88 silicone intake to make things easier and quicker.
Surprisingly enough the intercoolers use the same style quick connections as BMW/Kia. Always have extra machined pieces laying around so we used those along with hydraflow clamps on the other side.
