Sponsored by: Road Spy
What did you do to your 991 turbo today?
Old 06-10-2022, 02:57 PM
  #5056
vman932
vman932's Avatar
I used a slightly modified Home Depot tote (click for HDX 17 gallon link) to make my meth system quickly removable. Unscrew the meth line, unplug the electrical connector and everything lifts out. I also wanted the to use the tote keep any meth leaks or spillage from soaking into the factory carpet/liner. This proved to be fortuitous. After filling the tank and making the first pulls, I found the collar around the lid leaks. 🤦‍♂️ I found a couple other totes that fit without modification, but they were clear with a completely flat bottom. I wanted the black to better blend in and also wanted ribbed floor. The ribbed floor provides a recess to keep the mounting hardware on my tank straps from grinding into the carpet. I have an OEM frunk liner that I planned to use for this purpose, but the walls taper too much making the bottom area too small. With the tank in place, a single standard sized carry on will still fit. This is more than enough for me, but if the wife is also traveling, we can't get by on one carry on 🤣🤣🤣
The following 2 users liked this post by vman932:
Pb Pedis (06-10-2022), rodsky (06-11-2022)
Old 06-10-2022, 07:01 PM
  #5057
Pb Pedis
Pb Pedis's Avatar
Received 1,039 Likes on 657 Posts
Default Finally....
Finally got around to getting these Rennline screens installed....
The following 3 users liked this post by Pb Pedis:
Beezupra (06-10-2022), Big Swole (06-11-2022), rodsky (06-11-2022)
Old 06-10-2022, 07:59 PM
  #5058
worf928
worf928's Avatar
Received 1,655 Likes on 1,078 Posts
Originally Posted by rodsky
Dave - does it really take months for the paint to cure?
Based upon what I've been told over the years, PPF on non-factory paint is always dicey if you expect to remove the PPF and it is best to allow the paint to cure for many weeks. I plan to reconfirm with both my PPF guy and the body shop.
Sucks - why don't you fix it over the winter so keeping her off the road isn't as painful?
That's pretty much the plan. I'll get it fixed and allow it to cure over the winter with PPF in the spring.
First world problem: I'll just be 'forced' to drive one of the others. Gonna put the Summer shoes on the 718T tomorrow.
What does DDG stand for?
DDG is my Turbo's name. 'round here saying 'the Porsche' doesn't narrow it down.
Background for the name is in this post in my 2015 ED Thread:
https://rennlist.com/forums/991-turb...l#post12355074
rodsky (06-11-2022)
Old 06-11-2022, 09:37 AM
  #5059
vrybad
vrybad's Avatar
Yep, I've seen non-factory paint peel right off while removing PPF if the paint has not cured long enough.
Happened to the hood of my buddy's 97 Supra.
Removing that stuff always makes me a bit nervous.
Old 06-11-2022, 10:41 AM
  #5060
D1al911
D1al911's Avatar
You sir have me thinking. My main reason to not go the meth route is losing frunk space given we take a lot of road-trips. Thank you for the post!
A
Old 06-11-2022, 12:22 PM
  #5061
Big Swole
Big Swole's Avatar
Received 2,108 Likes on 1,328 Posts
Yup, meth would be far more enticing if it weren't for taking up so much space and require so much invasive wiring install.
The hp is very enticing though.
Old 06-14-2022, 03:04 PM
  #5062
2fcknfst
2fcknfst's Avatar
Received 4,124 Likes on 3,121 Posts
Got my winters back, refinished and unbent.
Considering how miserable its been here, they may actually go on very soon....
Old 06-14-2022, 11:39 PM
  #5063
onfireTTS
onfireTTS's Avatar
Received 1,119 Likes on 864 Posts
I one upped your skill set………
Old 06-15-2022, 12:07 AM
  #5064
2fcknfst
2fcknfst's Avatar
That looks irritating.
What happened?
Old 06-15-2022, 12:08 AM
  #5065
RadarP3C
RadarP3C's Avatar
Pot hole?
I usually only see that when riding on run-flats because of the stiff sidewall after hitting a pothole.
Old 06-15-2022, 12:45 AM
  #5066
onfireTTS
onfireTTS's Avatar
New ride with new tires. 530 miles Michelins 295 35 21 XL rated.
Bump in the road but nothing major. Right front was fine. Right rear……..
Discount Tire Manager thinks it’s a defect since the tread belts were fine.
Fingers crossed they help out.
Old 06-15-2022, 01:04 AM
  #5067
RadarP3C
RadarP3C's Avatar
I've used DT a couple times. They should take care of you. Keep us updated.
Old 06-15-2022, 10:37 AM
  #5068
Big Swole
Big Swole's Avatar
Not sure what you consider "miserable" but I'd probably trade with ya.
103-105* Heat index yesterday with so much humidity that I'm dripping after only 1-2 mins. of being out of the car on numerous calls / stops yesterday at work.
I HATE Summer time!!
Old 06-15-2022, 10:44 AM
  #5069
Pb Pedis
Pb Pedis's Avatar
Default Well....
Originally Posted by Big Swole
Not sure what you consider "miserable" but I'd probably trade with ya....103-105* Heat index yesterday with so much humidity that I'm dripping after only 1-2 mins. of being out of the car on numerous calls / stops yesterday at work....I HATE Summer time!!
Sir, I would gladly trade my south Florida weather/humidity with you anytime - imagine if your summer time *never* ended. The only silver lining is I can tell myself the weather is a key reason to get Meth.
Old 06-15-2022, 11:22 AM
  #5070
2fcknfst
2fcknfst's Avatar
What a bugger; sidewalls shouldn't do that, at least not without damaging the rim, hopefully it is the tyre and they fix it.
Quick Reply: What did you do to your 991 turbo today?
