Sponsored by: Road Spy
What did you do to your 991 turbo today?
Old 08-04-2021, 04:22 PM
  #3286
911dude41
911dude41's Avatar
Received 1,226 Likes on 705 Posts
Originally Posted by 2fcknfst
I have a very well documented history of destroying various pieces of body or trim I was trying to 'fix'.
That's a guarantee over here. IF I don't snap a tab on some sort of trim, I feel incredibly happy and accomplished. That's one type of car work I just can't finesse.
Old 08-04-2021, 06:05 PM
  #3287
2fcknfst
2fcknfst's Avatar
Received 4,025 Likes on 3,062 Posts
Got it back from the Dealer - turns out it wasn't a CV, rather, the strut top mount required some lubrication... never heard of that, but OK.
Also, the fuel sender was recalibrated - handy.
Old 08-04-2021, 06:34 PM
  #3288
worf928
worf928's Avatar
Received 1,614 Likes on 1,053 Posts
What were the symptoms as best as you can describe?
Old 08-04-2021, 06:40 PM
  #3289
2fcknfst
2fcknfst's Avatar
The front right axle was making a 'clicking sound; it became more pronounced as the wheel was turned to lock - history has taught me that would be a CV on its way out; Porsche thought the same thing too initially - they had the car since last Thursday, so it took them a bit to figure out it was a lube issue.
Old 08-04-2021, 07:29 PM
  #3290
pfbz
pfbz's Avatar
Received 2,805 Likes on 1,504 Posts
No clicking, but on a semi-related note... I
I've had have my 991 Turbo S in for some minor warranty repairs. They had the front belly cover off and noticed both my front, inside CV boots were damaged and they will be replacing them under warranty.
Now I've seen and heard of plenty of CV boots needing to be replaced on ~20 year old 996 Turbos (have one of those as well), but has anyone else needed CV boots on their 991 Turbo? Although it does have 50K miles, I was a bit surprised.
Old 08-05-2021, 11:31 AM
  #3291
worf928
worf928's Avatar
Thanks.
Very strange.
As you expected, “Click” is usually metal on metal. Things that respond to lube are usually a material with a hardness quite a bit short of metal.
IMO, There’s more to this story that we won’t figure out for a while yet.
Old 08-05-2021, 12:06 PM
  #3292
2fcknfst
2fcknfst's Avatar
Could very well be, but for now, clicking is gone and the fuel is reading the correct level, so that is a plus.
Old 08-05-2021, 04:26 PM
  #3293
Pb Pedis
Pb Pedis's Avatar
Received 1,034 Likes on 653 Posts
Default ?
Stock springs/suspension or aftermarket?
Old 08-05-2021, 04:27 PM
  #3294
Pb Pedis
Pb Pedis's Avatar
Default ?
Old 08-05-2021, 05:02 PM
  #3295
Rausky
Rausky's Avatar
Put a quicksilver catback exhaust on (muffler delete). Car sounds way better but still a bit too quiet I think. Any recommendations for cat delete pipes? I'm thinking Soul if they're in stock.
Soul Performance (08-06-2021)
Old 08-05-2021, 05:12 PM
  #3296
MotoJB
MotoJB's Avatar
Any cat delete pipes should work...I used Soul with a couple exhaust setups and they were fine/good.
That exhaust will be LOUD after the cat delete and expect a good amount of drone/resonance as well.
Old 08-05-2021, 06:01 PM
  #3297
2fcknfst
2fcknfst's Avatar
Originally Posted by worf928
Thanks.
Very strange.
I spoke to soon; clicking noise is still there, front left axle, very pronounced when turning to, or in lock.
Techart springs, however, the noise is associated with the rotation of the wheel.
Old 08-05-2021, 06:06 PM
  #3298
worf928
worf928's Avatar
As the risk of telling you something you already know: when you take it back take the tech on a drive and demonstrate how to make it click.
Old 08-05-2021, 06:07 PM
  #3299
2fcknfst
2fcknfst's Avatar
Yep, already on it - I am going away on a trip so I have said I will bring it down and show them the issue - mind you, on the work order I just got back, they did hear the clicking and it was noted.
We shall see...
Old 08-05-2021, 07:05 PM
  #3300
Rausky
Rausky's Avatar
Any idea if 20x9 front 45 and 20x11 rear 45 will fit on a 14 TTS?
Quick Reply: What did you do to your 991 turbo today?
