How many 15-16 gt3's have engine replaced?
#2417
#2418
Originally Posted by krisa9977
I was told they will put a newer version of the engine. Previous G engine was replaced on March 2016
I think Mwar will be able to share the info when his new engine comes
#2421
I already asked that before on this topic with no reply but anyone using a 5w50 or 10w60 oil got the dlc engine problems?
I know porsche reccommended oil for the gt3 is 5w40 but some owners that track the car in Europe are using other oils and I don t know if that could make a difference or not.
#2423
#2424
#2426
I'm a bit sceptical regarding to RS and R. The parts catalogue says the topend is exactly the same. So this engines should also be prone to the problem.
With later G (G1/G6 however...) they introduced the DLC coated camshafts. Maybe thats the solution - but not all the RS have these camshafts installed.
#2427
And if, at some point this problem does happen, Porsche will step up. Absolutely nothing to worry about.
#2428
As was discussed by Dr. Walliser, there are enough differences (springs, redline, etc.) that these RS and R engines are not affected. They were tested using the same testing procedure that reproduces this problem on some GT3's. No issues. Also, no reports of RS/R failures that we know of.
So far there is a very general `He explained that there are many differences between the GT3 and R/RS engines.' statement.
There are a lot of technically oriented people here that are only satisfied by understanding specifically why R and RS are considered to not be affected by Porsche.
#2429
It may help to put details such as springs and red line on page 1 of your COG announcement thread.
#2430
Sent a 2016 to the dealer two weeks ago after I noticed something internally wrong with the engine in the high RPM's. Was told a cylinder had issues that they needed to determine. It was not misfiring and I new it was mechanical before it was sent to the dealer. They determined it wasn't an easy fix and a new engine is on its way to the dealer!!! This is very very exciting new for me! I'm very happy to get a fresh new engine in the car, now the next thing i need is a new clutch and I'm golden
