991 GT3, GT3RS, GT2RS and 911R 2012-2019
Sport Chrono Package incl. Porsche Track Precision App
Old 11-18-2014, 11:59 PM
  #76
mundman
mundman's Avatar
Originally Posted by Mech33
Apple iOS App Store on an iPhone. Not sure if the Android version is available yet.
I can't find it! What's it called?
Old 11-19-2014, 12:06 AM
  #77
Mech33
Mech33's Avatar
Oops. "Porsche Track Precision"
Old 11-19-2014, 12:10 AM
  #78
mundman
mundman's Avatar
Found it
Old 11-19-2014, 12:15 AM
  #79
doubleurx
doubleurx's Avatar
Originally Posted by Zucc
My original order was a 2014, when they bumped me to a 2015 they honored the original price since I had speced that car with Sports Chrono.
Ah yes! I forgot about that deal. Excellent!
Old 11-19-2014, 01:27 AM
  #80
provoke
provoke's Avatar
Thanks again for the effort! Any chance you'd be willing to post a link to an example datafile output (or perhaps email it via PM)? I'm curious on how much data is available, what the data rate is (especially on the position tracking), etc.
The main potential complaint with this Porsche Track Precision solution is that the GPS data rate is too low (1 Hz from the phone, or 1 Hz from the car's GPS), compared to the 10 Hz or 20 Hz of the "professional" VBox systems.
Here ya go.. There are 3 images. 2 are of the data points and 1 is of the "lograte hz" error.. I put in1hz based on ur comment but the speed is way off.. I wasn't doing over 100mph on a 25mph road.. I think I was doing about half of that..
Old 11-19-2014, 02:18 AM
  #81
Mech33
Mech33's Avatar
Thanks. What's the file format? Could you just post the data or link to the log file itself? I assume the position coordinates are embedded in the file along with time stamps showing the log rate.
Old 11-19-2014, 12:08 PM
  #82
provoke
provoke's Avatar
.vbo you can also export in .csv and .kml or Porsche track precision app. Let me go over the file.. I just don't necessary want to post the logfile if it contains my vin#.
Old 11-19-2014, 02:59 PM
  #83
Mech33
Mech33's Avatar
Sounds good. If you could export in CSV and then just paste some of the lines here we should be able to tell the logging rate for position (if it is in the file, that is).
Old 11-19-2014, 05:56 PM
  #84
provoke
provoke's Avatar
Try this....
https://www.dropbox.com/sh/hznnblbsb...9TARktHTa?dl=0
Old 11-19-2014, 08:13 PM
  #85
orthojoe
orthojoe's Avatar
Based on the data in that file, it looks like output at 10Hz, which means lap times are accurate down to 0.1 seconds.
However, it's not clear if data points are interpolated. Harry's lap timer interpolates data points, IIRC.
Old 11-20-2014, 12:24 AM
  #86
Mech33
Mech33's Avatar
Yeah the 10 Hz data looks pretty decent. The car certainly has additional sensors (wheel speeds for example) that can help with interpolation over GPS alone.
Old 11-20-2014, 07:42 AM
  #87
Slip
Slip's Avatar
Looking for the best way to mount the iPhone for video duties so that it can link / feed video to the track precision app. Have just ordered this setup:
http://www.optrix.com/store/roll-bar-xd5-bundle/
I got the cage mount but you can also get it for a dash or windscreen mount.
Old 11-20-2014, 02:05 PM
  #88
provoke
provoke's Avatar
When I load the file at 10Hz it has the max rate of speed at 105mph.. Something is off.. I recall maybe doing like 65or so...
Old 11-20-2014, 02:45 PM
  #89
Mech33
Mech33's Avatar
I think the units of the file are all SI (distances in meters, accelerations in m/s^2). Some rough calculations I made for one part of the file showed you driving at about 39 mph as a result.
Old 11-20-2014, 10:44 PM
  #90
Tre
Tre's Avatar
I've been using the Optrix case and mount for my track bike, but I highly recommend Ram mounts for car window set ups. I've used the Ram mount option for a couple years mounted immediately below the rear view mirror with the iPhone in landscape mode. Note, both hardware setups were for use with the Harry's Laptimer software.
Quick Reply: Sport Chrono Package incl. Porsche Track Precision App
