991 GT3, GT3RS, GT2RS and 911R 2012-2019
Consolidated 991RS thread
Old 07-30-2014, 03:03 PM
  #1186
Petevb
Petevb's Avatar
Originally Posted by Nizer
But you're addressing reducing lift while my comment was directed at generating downforce and while related they're not the same.
I don't know that I'd separate the two issues as you're trying to do, as they are entirely inter-related for two reasons. First, to generate total downforce you need to cancel out any lift that is created. Second, the angle and condition of the incoming airflow to the rear wing largely determines how difficult it is for the wing to create downforce.
A wing's job is to "turn" incoming airflow, redirecting its path- it must do this in order to create lift or downforce. However if the air is already turned, as on the back of the early 911, then the car is acting as a wing itself. The wing needs to "turn" the air back to cancel this out, which is difficult because it needs both a lot of redirection and because it's already quite turbulent before it gets to the wing, meaning the wing can't function efficiently. This is fake, but it's exactly why it's hard to make downforce on an early 911:
And why it's easy on a modern 991:
Hence I don't think you can talk about the difficulty in generating downforce on a 911 rear without discussing the rear rake, etc.
In reality it's actually not hard to make rear downforce in either case- put a big enough wing on the back and the rear is going down. Making downforce efficiently or at the front is a very different matter, however.
Old 07-30-2014, 04:03 PM
  #1187
Nizer
Nizer's Avatar
Received 1,863 Likes on 963 Posts
Got it. Now when the rear wing snaps off my Cup going up through the esses at The Glen and I have an intimate encounter with the blue bushes I will blame it on a sudden and dramatic reduction in negative lift as opposed to a loss of downforce. Wait, crap! I think that's a redundant statement. Or am I just being pedantic? I'm confused.....
Old 07-30-2014, 04:46 PM
  #1188
mgent
mgent's Avatar
Isn't downforce generated by the flow of air of the underside of surfaces more than the top side, and management of flow on the top side generally to manage drag?
If that's correct, there could be fairly significant gains by changes on the underside of the car - splitter, floor, diffuser - that are not really visible on the test mules... I'm not smart enough to gauge the magnitude of any potential changes, but that could drive significant downforce resulting in the changed tire load rating..
That being said, I would expect the 918's clean sheet design to take advantage of more of these areas than a package on an existing car...
Old 07-30-2014, 05:10 PM
  #1189
cbweaver1
cbweaver1's Avatar
Originally Posted by MileHigh911
Just guessing here: Perhaps Porsche has finally figured out how to add aero downforce with diffuser technology?? The rake of the wing on the 991 RS videos is not that great. By using the side scoops to run air into the engine compartment, and exiting out the rear low, maybe they have finally figured out how to keep engine airflow adequate, and use efficient downforce methods to not increase drag? just thinking outside the box, as the overall design of what we have seen so far is not that much different than the gt3, besides the air scoops.
Correct, more down force than on a 918 hence the higher sidewall ratings. Final design on rear air inlets with mesh a la the RSR will have a dual purpose: feed more into the motor than standard GT3 while an additional internal opening near the rear tires will create negative pressure reducing underside lift in order to generate more down force. The front vents are in place to do the exact same thing near the front tires to even out the balance. It is not on the Cup (for the moment) but it is not a gimmick either. There will be no one "killer" aero element as on previous GT3's (massive rear wing) to get massive down force but rather the sum of the parts, their design and specific location on the 991 RS which will separate it over the standard GT3 more so than any previous iteration before it.
How do I know this? The same little birdie that told me exactly what we are seeing and hearing on the test mule over a year ago while sipping on a cappuccino. They will sell every last one of them and at a premium.........
Old 07-30-2014, 05:39 PM
  #1190
paver
paver's Avatar
Ask the little birdie when its debut is.
Old 07-30-2014, 06:27 PM
  #1191
Petevb
Petevb's Avatar
It can be either. Generally the biggest improvements in lift to drag ratio can be found on a car's underside, if practicalities and rules allow changes there. Often they do not. The trend recently has been to do more with the underside.
They are certainly doing some of that, but there are always telltales when they do. The issue is that making downforce with the underside requires getting air that gets under the car out, so you look for the diffusers, vents, etc.
In this case a telltale is the fender vents- modern cars use variations of those to improve front downforce by removing air from behind the front wheel into a low pressure area. These vents take different forms- on the 918 there are multiple vents in the flank behind the front wheel:
Similar on the La Ferrari and P1, they remove air from under the front of the car to turn that into a low pressure area:
The fender vents on the RS will be performing a similar function- that's how they are getting air out under the front, so we can guess there is some trickery going on under there.
In back you would traditionally look for a diffuser, but as we've said there is a motor and exhaust in the way of anything large, blocking the direct exit path. Alternatives are behind the rear wheels, either with wheel arches cut away or with fender vents. Looking closely at the rear flanks of the red model's bumpers it does look like there could be quite a large vent in that location- if so that would do it. You can see a similar but less sculpted feature on the RSR in the location you'd be looking at:
And you can maybe see something like it below:
Old 07-30-2014, 06:33 PM
  #1192
Petevb
Petevb's Avatar
Sounds very much like your source gave you good info...
Old 07-30-2014, 07:16 PM
  #1193
<3mph
<3mph's Avatar
Thanks, everyone, for the really great info. I have learned so much from reading your posts! Please keep discussing!!
Old 07-30-2014, 09:30 PM
  #1194
TRAKCAR
TRAKCAR's Avatar
Received 1,640 Likes on 762 Posts
I want it Big *** Downforce.
Old 07-30-2014, 09:49 PM
  #1195
Z356
Z356's Avatar
I am with you, brother!
Saludos,
Eduardo
Carmel
Old 07-30-2014, 10:38 PM
  #1196
Zucc
Zucc's Avatar
Definitely a Turbo!
Old 07-31-2014, 10:33 AM
  #1197
0Q991
0Q991's Avatar
Not sure if posted already:
http://www.carmagazine.co.uk/Secret-...patent-photos/
Pretty clear look...
Old 07-31-2014, 11:14 AM
  #1198
Nizer
Nizer's Avatar
Nope. Nice find!
Old 07-31-2014, 11:15 AM
  #1199
Bill_C4S
Bill_C4S's Avatar
+1 and thank you!
Old 07-31-2014, 11:49 AM
  #1200
CAlexio
CAlexio's Avatar
Received 1,973 Likes on 917 Posts
Among other things, I love how the rear deck is black all the way down past the glass, as well as the flaps" that are created at the sides of the rear bumper..
Ok, so the big question.. What should they/can they charge for this now over the gt3?
Quick Reply: Consolidated 991RS thread
