Consolidated 991RS thread
#1036
I've been hoping, but it may pose more of a challenge to meet noise and emissions standards. Since the 964, the RSR has always used 6 throttles with a plenum intake rather than stacks like the 911. This gives better low-end torque but also mutes the intake noise (maybe this is an advantage for reintroduction into a road car)
#1037
I suspect that they may have taken in pumping and cooling losses inherited with moving all that coolant to the front of the car and back again. Could be instead of intercoolers it has dual rads or oil/tranny/diff(?) coolers under the ducts for more efficient cooling.
#1038
Intercoolers are required on FI cars to cool the induction air and increase the volumetric efficiency by increasing charge density, which is independent from engine or transmission cooling functions.
#1040
As far as I know, the GT3 and Turbo both run the same 305/30-20 and 255/35-20 tire size. Hard to imagine the RS needing larger wheels/tires when it's only 5% more powerful than the GT3 and less powerful than the Turbo, which it shares the basic body shell with.
#1041
#1045
mule in the pictures has no GT3 style decklid, that in previous versions provided
a ram air intake directing cold air thru a sealed air path into the engine airbox, since no such feature appears on this car, the speculation is that it is using the
intake mechanism from the RSR race car which ducts the air from these flank ducts into the engine ... its all speculation
#1046
Definitive news: ITS NOT A TURBO according to pistonheads, and your own ears. Also, the wing is huge, the front fender vents have disappeared, and the PDK seems to shift even faster than on the gt3... Wait for the still pics at the end Video Link: http://youtu.be/pUeYCgmjjAg
#1047
I recently spoke to a gent in the service dept of a Porsche dealer and he said that he's heard rumors that the new GT3RS will be available with both a PDK and a 6 speed manual transmission.
Just passing this on.
#1049
Front fender vents over the wheel, not the rear air intakes.
And in response to the wheel size question... Those rears look to be of a larger diameter than fronts, so not like the turbo.. If the fronts are same as gt3, then are those 21" wheels in rear?!?
