991 GT3, GT3RS, GT2RS and 911R 2012-2019
991.2 Oil Leak
Old 10-09-2018, 03:02 PM
GrantG
GrantG's Avatar
Received 5,129 Likes on 2,889 Posts
Originally Posted by Wind911
Funny, that's what I did with my 996GT3. The bottom of engine was always damp. Switched to Motul Xcess 8100 5w-40 and is bone dry ever since.
But if this is an oil pipe that is defective at the crimp like in OP's car, I'd like to have it replaced.
I think I've seen posted in another thread a crimped area on the oil tank reservoir (seam for welding), not a pipe. Hmm, didn't know the pipe was a separate issue...
Old 10-09-2018, 03:58 PM
Wind911
Wind911's Avatar
Yeah the pipe is a separate issue. This pipe feeds oil through the center of crank pulley to the new hollowed crank.
Old 10-09-2018, 04:29 PM
GrantG
GrantG's Avatar
Thanks!
Old 10-29-2018, 09:04 PM
djcxxx
djcxxx's Avatar
I also found a similar oil droplet forming on the metal piece outside of crank pulley as JC68. No oil stains on the diffuser tray yet. Car has 2000 miles. It should be the oil pipe assembly that supplies oil to the crank. This is a 991.2 GT3/RS only part as now we have hollow crank that oil can flow through. I suggest all of .2 GT3/RS owners should take a look at yours.
Just had this problem dx/rx on my .2. Oil droplets in diffuser tray. 1800mi. Probably good idea to check inside diffuser for this issue.
Old 12-06-2018, 11:21 PM
Dot23RS
Dot23RS's Avatar
If it’s that slow, maybe switching to 5W40 oil would help or fix it...
5W-40 is fine or better yet 5-50 for track toys but for cars more oftenly used 0W-40 is the only oil (0W) that will get warm enough within 5-10min to be able to drive over 2k rpm.
Old 12-09-2018, 02:52 PM
JC68
JC68's Avatar
My paperwork shows new oil pipe part number ends with 93 while the PET shows 92. Should be an updated part.
There is a 300 mile .2 GT3RS in for the same oil leak. Looks like a common problem.
Old 12-12-2018, 08:10 PM
orthojoe
orthojoe's Avatar
Looks like my RS may have the same problem.
Old 12-12-2018, 08:19 PM
disden
disden's Avatar
Received 1,223 Likes on 479 Posts
Yikes, not good. I will have to look at mine too. Suspect this is why all those GT3s and RSs are now being held up at port. my 991.1 RS was a freaking tank, never had a single issue. In my 991.2 RS I've already had a headlamp failure, now suspect this issue will be a mass recall. Bummer
Old 12-12-2018, 08:46 PM
robmypro
robmypro's Avatar
Received 1,784 Likes on 1,027 Posts
I wouldn’t drive it Joe. Just get it to the dealer.
Old 12-12-2018, 08:48 PM
orthojoe
orthojoe's Avatar
Already at the dealer
Old 12-12-2018, 08:51 PM
GrantG
GrantG's Avatar
Joe - what part is in your photo? Doesn’t look like the crank pulley...
Old 12-12-2018, 08:53 PM
orthojoe
orthojoe's Avatar
Oil line, but dealer says leak is coming from pdk
Old 12-12-2018, 09:00 PM
robmypro
robmypro's Avatar
GrantG
GrantG's Avatar
Ok, good luck for speedy fix!
Old 12-12-2018, 09:56 PM
n2cars
n2cars's Avatar
So, possibly a PDK issue and not an engine problem? I just inspected my Touring ( with limited tools and space) and not a drop of oil was found anywhere. Also put my VIN# in Porsche's Recall web site and nothing showed up as of 12/13/2018.
Quick Reply: 991.2 Oil Leak
