What did you do with your 987 today?
Old 01-09-2024, 03:36 PM
  #1411
Zach L
Zach L's Avatar
Originally Posted by Van Larson
Wouldn’t it be nice if someone could make an affordable manually controlled Front Axle Lift kit to retrofit….
KW makes a FAL system that can be added to their coilovers.
Old 01-13-2024, 07:17 PM
  #1412
Ric In RVA
Ric In RVA's Avatar
Replaced my cracked pipe running from the AOS to the intake and fixing a vacuum leak on my 2009 987.2 2.9 manual.
Then added a sprint booster.
I had high expectations from others comments but was still blown away. The sprint booster is the way this car should have been delivered.
Then I fixed the Dinan rear shock mounts on my 128i....
scootr (01-13-2024)
Old 01-13-2024, 09:47 PM
  #1413
scootr
scootr's Avatar
If Porsche delivered the Boxster with the DSC suspension mod for PASM and sprint booster type throttle response they would never sell a 911
They do this with a purpose and a plan.
Old 01-13-2024, 11:07 PM
  #1414
Aussie skypig
Aussie skypig's Avatar
With a 3.8 Engine (Nickasil bores/no IMS bearing.)and a limited slip diff, in my 987.1 CS, I struggle to see which 911 I’d prefer. (Within even double my budget)
I really enjoy driving this car.
Before I bought it, a GT3 was my holy grail, with a GT4 a close second. Both crazy expensive in Australia. (Used $A500k/$A250k).
I now don’t believe I could use, or enjoy, any extra power or handling on any public road. My Engine has a massive wave of midrange power which just suits everything perfectly. “Performance” driving can be achieved lower in the rev range, making the tallish gear ratios seem lower.Using 3500 - 6000rpm is incredibly satisfying. Regularly enjoying shifts between 2nd and 3rd, sometimes 4th, because you can, and occasionally 1st - I drive some tight back roads.
So much fun.
The following 2 users liked this post by Aussie skypig:
Julian_KCMO (01-15-2024), scootr (01-14-2024)
Old 01-18-2024, 02:49 PM
  #1415
ekam
ekam's Avatar
Drove to work this morning and felt the shifter was disengaged when I tried shifting from 1st to 2nd.
Car stuck in 1st gear but no way to get it to neutral as the shifter just flopped around.
Flat bedded to dealer and was told the car needs new shifter cables, thankfully they actually have them in stock. When I got this car 6 years and 100k+ km ago I had the revised cables installed. I guess the cable(s) just broke due to wear from rush hour driving.
Old 01-18-2024, 03:05 PM
  #1416
KrisA
KrisA's Avatar
So even the updated cables suck. That sucks.
Old 01-18-2024, 03:12 PM
  #1417
ClemCLone
ClemCLone's Avatar
What I was gonna say
Old 01-18-2024, 03:22 PM
  #1418
ekam
ekam's Avatar
I'm not sure, because this is my daily and I get stuck in traffic and do a lot of shifting because of that.
Old 01-18-2024, 05:11 PM
  #1419
The_Texan
4th Gear
The_Texan's Avatar
I took off the factory 17" wheels and added 19" optional boxster S wheels. LOVE the way they look. Also added 15mm spacers, and of course wider 235/265 tires.
The following 5 users liked this post by The_Texan:
Chris MI 987 (01-19-2024), Julian_KCMO (01-19-2024), quickboxster (01-18-2024), sasilverbullet (01-19-2024), The Duke (01-18-2024)
Old 01-18-2024, 05:46 PM
  #1420
old man neri
old man neri's Avatar
Do you know if the updated bracket was also installed with the updated cables? It probably was but you never know.
Old 01-18-2024, 07:16 PM
  #1421
Zach L
Zach L's Avatar
Looks great! Technically, they're Cayman S II wheels
Old 01-18-2024, 07:36 PM
  #1422
The Duke
The Duke's Avatar
I never thought I'd see the day where anyone, let alone me, would be able to correct Zach, but they're the Carrera S II wheels. :-)
And - yes - they do look great!
Old 01-19-2024, 12:57 AM
  #1423
Caveman Smash
Caveman Smash's Avatar
The factory R suspension is perfect IMO... I use for track days, autocross, and weekend driving. Have had full aftermarket coilovers on previous vehicles and the R suspension is just as capable while being much more composed.
The 'full' kit also includes the R rear swaybar, and the rear springs are transmission dependent, FYI.
Do you know if the sway bars from the R/Spyder suspension are hollow or solid?
Old 01-19-2024, 08:07 AM
  #1424
ekam
ekam's Avatar
Yes 6 years back Porsche had already discontinued the old cables and the revised cables must be ordered with new updated bracket as part of a kit.
Old 01-19-2024, 01:06 PM
  #1425
Zach L
Zach L's Avatar
Touche! lol
Zepper (01-24-2024)
Quick Reply: What did you do with your 987 today?
